TOS roms USA or English?
Rdawg67
Post by Rdawg67 »
Hi,
Im in the USA and have a 1040STE
I want to upgrade the TOS but I don't understand which version to get.
Almost all the TOS have and English and USA version.
Which do I get?
What are the differences?
Thanks
R
Darklord
Re: TOS roms USA or English?
Post by Darklord »
Rdawg67 wrote: 10 Feb 2026 23:26 Hi,
Which do I get?
Thanks
R
You would want to get the USA version. There are subtle differences between colonial English and the King's English. :lol:
Just a quick demonstration:
Whats the difference between grey and gray?
One is a color and the other is a colour.
See what I mean? :)
When I installed TOS v3.06 ROMs into my Pak 68/3 accelerator board in my STacy, I went through that.
Just pick the US version and you should be fine.
HigashiJun
Post by HigashiJun »
And your US keyboard will be mapped the UK way.
Rdawg67
Post by Rdawg67 »
Thanks for the help and clarification I appreciate it.
Darklord wrote: 11 Feb 2026 01:26
Which do I get?
Thanks
R
See what I mean? :)
Rdawg67
Post by Rdawg67 »
HigashiJun wrote: 11 Feb 2026 01:59 And your US keyboard will be mapped the UK way.
Thanks!
Cyprian
Post by Cyprian »
US TOS boots in 60Hz and UK in 50Hz.
http://260ste.atari.org
Darklord
Post by Darklord »
Cyprian wrote: 11 Feb 2026 14:32 US TOS boots in 60Hz and UK in 50Hz.
Interestingly enough, that can actually be an issue. Holger Zimmerman was
nice enough to do a US version of the modified TOS v3.06 ROMs for the
Pak 68/3 board in my STacy, and everything seemed fine for years.
Until I put in the RGB2HDMI mod. It uses "profiles" and I didn't realize it
at first but I couldn't get it to select a 60hz profile - it always defaulted
to 50hz.
Long story short, it was the TOS ROMs forcing it into 50hz mode. Holger
redid them and that fixed that.
Cyprian
Post by Cyprian »
Darklord wrote: 11 Feb 2026 17:52
to 50hz.
fortunately it can be fixed by placing 50/60Hz application in AUTO folder or by modifying the TOS header "os_conf" (byte $1D) in ROM:
"os_conf The component os_conf contains the so-called NTSC/PAL flag in its lowest bit; if this bit is set, then the machine has a PAL video system, if cleared NTSC."
https://freemint.github.io/tos.hyp/en/OSHEADER.html
