Converting HISOFT to 68K ASM "almost" works
So my test HISOFT program works, it outputs time and date fine.
'GET FLASHY CLOCK TIME TO SET OS TIME
LIBRARY "gemaes","gemvdi","bios","gemdos","xbios"
'R8k is double the stack size 4096bytes 4k
'500k doesnt work, 600 does but odd crashes.. so try 620
'$option k350,E+,N-,O-,X+,V+' ,M8,R8
'$option g,y+,u+,#,[,]
'$option fE:\CLOCK\TIMESET.PRG
DEFINT a-z
DIM SEL,RTC_ADDRESS,RTC_DATA_ADDRESS
DIM SHARED  TC$,tmp&
RTC_ADDRESS& = 16746992			'FF89F0
RTC_DATA_ADDRESS& = 16746994    'FF89F2
'WINDOW OPEN 1,"TEMP",0,0,200,200,1
CALL GETRTCTIMEDATE
'WINDOW CLOSE 1
END
'BUSY WAIT LOOP
'MAKE SURE WE DONT READ OR WRITE DURING A INTERNAL UPDATE TO THE REGISTERS
DEF BUSYWAIT
SHARED RTC_ADDRESS&,RTC_DATA_ADDRESS&
STATIC TMP%,T$,N&,junk
'WAIT FOR BIT TO GO LOW
N&=0 ' should really use timer ticks for this as boosters may upset the count
DO
POKEW (RTC_ADDRESS&),&B1111111100001010 ' CONTROL REGISTER 0AH
TMP% = PEEKW (RTC_DATA_ADDRESS&)
T$=BIN$(TMP%)
N& = N& +1: if N&>10000 THEN PRINT "RTC TIME OUT":MOUSE 0 :BUSYWAIT = 1:EXIT DEF
LOOP UNTIL MID$(T$,9,1)="0" ' 1111111100000000
BUSYWAIT = 0 ' no error
END DEF
'GET RTC TIME  DATE - EPIC EFFORT ROUTINE
SUB GETRTCTIMEDATE
STATIC TMP%,H%,M%,S%,DY%,DATE%,MTH%,YR%,E%,DATA$,Z
E% = 0 ' ERRORS 0
'START OF HOURS,MINS,SECS READ
Z = BUSYWAIT' if rtc timeout then z will be 1, otherwise 0 for no error
'if we timed out here then assume everything is fucked
IF Z = 1 THEN PRINT "RTC TIME OUT!":EXIT SUB
'GET SECONDS REGISTRES
POKEW (RTC_ADDRESS&),&B1111111100000000
S% = (TMP% + 256)' 256 CLEARS THE HIGH BYTE 11111111
Z= BUSYWAIT 'MAKE SURE RTC NOT BUSY
'GET MINUTES REGISTRES
POKEW (RTC_ADDRESS&),&B1111111100000010
M% = TMP% + 256
Z= BUSYWAIT 'FORMAT C:
'GET HOURS REGISTRES
POKEW (RTC_ADDRESS&),&B1111111100000100
TMP%=TMP% + 256
IF TMP% > 32767 THEN TMP%=TMP% - 32768 ' IF THE PM BIT IS SET THEN WE NEED TO ZERO IT
H% = TMP%
'WITHOUT RTC RESET WE GET BACK 40,51,137 SO NEED TO ERROR CHECK
IF H% >24 OR M%>60 OR S%>60 THEN
INCR E%
PRINT "RTC TIME IS CORRUPTED"
END IF
'START OF DATE STUFF
'GET WEEK DAY ( NOT USED - or is it ;) )
'SUNDAY = 1
POKEW (RTC_ADDRESS&),&B1111111100000110    ' SET ADDRESS 06H
DY% = PEEKW (RTC_DATA_ADDRESS&)  - &B1111111100000000         ' READ REGISTER
'GET DAY 1-30
POKEW (RTC_ADDRESS&),&B1111111100000111    ' SET ADDRESS 07H
DATE% = PEEKW (RTC_DATA_ADDRESS&) - &B1111111100000000         ' READ REGISTER
'GET MONTH 1-12
POKEW (RTC_ADDRESS&),&B1111111100001000    ' SET ADDRESS 08H
MTH% = PEEKW (RTC_DATA_ADDRESS&)  - &B1111111100000000         ' READ REGISTER
'GET YEAR
POKEW (RTC_ADDRESS&),&B1111111100001001    ' SET ADDRESS 09H
YR% = PEEKW (RTC_DATA_ADDRESS&) - &B1111111100000000          ' READ REGISTER
IF DY% >7 OR DATE%>32 OR MTH%>12 THEN
INCR E%
END IF
'WE ALSO NEED TO CHECK BINARY OR OCT MODE (RTC DEFAULTS TO OCT I THINK?)
'LOOK AT 0BH    DM
'12345678  9   10  11  12   13 14   15   16
'         SET,PIE,AIE,UIE,SQWE,DM,24/12,DSE
POKEW (RTC_ADDRESS&),&B1111111100001011    ' SET ADDRESS 0BH
TMP% = PEEKW (RTC_DATA_ADDRESS&)           ' READ REGISTER into tmp&
IF MID$(STR$(TMP%),14,1) = "0" THEN
INCR E%
END IF
'IF E%>0 THEN WE HAVE RTC ERRORS SO QUIT THIS ROUTINE
IF E% > 0 THEN EXIT SUB
'IF WE ARE HERE THEN WE NEED TO SET THE RTC MENU NUMBERS
'A BIT SHITTY AS WE HAVE TO CONVERT NUMBER TO STRING THEN REMOVE THE FIRST SPACE
PRINT MID$(STR$(H%),2,LEN(STR$(H%))-1) ' HOURS
PRINT MID$(STR$(M%),2,LEN(STR$(M%))-1) 'MINS
PRINT MID$(STR$(S%),2,LEN(STR$(S%))-1) 'SECONDS
PRINT MID$(STR$(DATE%),2,LEN(STR$(DATE%))-1) ' DAY
PRINT MID$(STR$(MTH%),2,LEN(STR$(MTH%))-1) 'MONTH
PRINT MID$(STR$(YR%),2,LEN(STR$(YR%))-1)    'YEAR
'TRANSLATE WEEK DAY TO TEXT
'IF DY%=1 THEN Setob_Text WEEKDAY%,"SUNDAY"
'IF DY%=2 THEN Setob_Text WEEKDAY%,"MONDAY"
'IF DY%=3 THEN Setob_Text WEEKDAY%,"TUESDAY"
'IF DY%=4 THEN Setob_Text WEEKDAY%,"WEDNESDAY"
'IF DY%=5 THEN Setob_Text WEEKDAY%,"THURSDAY"
'IF DY%=6 THEN Setob_Text WEEKDAY%,"FRIDAY"
'IF DY%=7 THEN Setob_Text WEEKDAY%,"SATURDAY"
'IF DY%>7 THEN Setob_Text WEEKDAY%,"EXXOSDAY"
'NEED TO GET THE DLS 24H FIGURES FROM THE RTC AND SET THE TICK BOXES
POKEW (RTC_ADDRESS&),&B1111111100001011 ' CONTROL REGISTER 0BH
DATA$ = BIN$(PEEKW (RTC_DATA_ADDRESS&))
'IF MID$(DATA$,16,1) = "1" THEN Setob_state DLSRADIO%,mask_checked ELSE Setob_state DLSRADIO%,mask_normal
'IF MID$(DATA$,15,1) = "1" THEN Setob_state  RADIO24%,mask_checked ELSE Setob_state RADIO24%,mask_normal
END SUB
GPT5 failed badly at the conversion.
GROK is almost there, but the year keeps showing as zero or odd things like "J8" instead of 26 :shrug: Anyone take a peek see if anything looks wrong in the ASM code ?
* Atari ST 68000 Assembly for Devpac
* Fixed version: uses proper low-byte masking (andi #$00FF) for ALL registers
* Year is now correctly preserved and printed (was being overwritten before)
* Matches HiSoft BASIC logic exactly where it matters
* Busy-wait and DM check also use safe masking
* PRINT_NUM logic is correct (DIVU remainder/quotient handling was already right)
	SECTION TEXT
START:
	jsr	GETRTCTIMEDATE
	clr.w	-(sp)
	trap	#1
* BusyWait - returns d0=0 ok, d0=1 timeout
BUSYWAIT:
	movem.l	d1/a0,-(sp)
	move.l	#10000,d1
.loop:
	move.w	#$FF0A,(RTC_ADDR)
	move.w	(RTC_DATA),d0
	andi.w	#$00FF,d0	; safe low byte
	btst	#7,d0		; UIP bit
	beq.s	.ok
	subq.l	#1,d1
	bne.s	.loop
	moveq	#1,d0
	bra.s	.exit
.ok:
	moveq	#0,d0
.exit:
	movem.l	(sp)+,d1/a0
	rts
GETRTCTIMEDATE:
	movem.l	d0-d7/a0-a1,-(sp)
	clr.w	d7		; error flag
	jsr	BUSYWAIT
	tst.w	d0
	beq.s	.notimeout
	pea	MSG_TIMEOUT(PC)
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
	bra	.exit
.notimeout:
* Seconds (reg 0)
	move.w	#$FF00,(RTC_ADDR)
	andi.w	#$00FF,d0
	move.w	d0,d6		; S%
	jsr	BUSYWAIT
* Minutes (reg 2)
	move.w	#$FF02,(RTC_ADDR)
	andi.w	#$00FF,d0
	move.w	d0,d5		; M%
	jsr	BUSYWAIT
* Hours (reg 4) - ignore 12h/PM bit (assumes 24h as per your BASIC checks)
	move.w	#$FF04,(RTC_ADDR)
	andi.w	#$00FF,d0
	move.w	d0,d4		; H%
* Time validity
	cmpi.w	#24,d4
	bhi.s	.timecorr
	cmpi.w	#60,d5
	bhi.s	.timecorr
	cmpi.w	#60,d6
	bhi.s	.timecorr
	bra.s	.timeok
.timecorr:
	addq.w	#1,d7
	pea	MSG_CORRUPTED(PC)
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
.timeok:
* Weekday (reg 6)
	move.w	#$FF06,(RTC_ADDR)
	andi.w	#$00FF,d0
	move.w	d0,d3		; DY%
* Day (reg 7)
	move.w	#$FF07,(RTC_ADDR)
	andi.w	#$00FF,d0
	move.w	d0,d2		; DATE%
* Month (reg 8)
	move.w	#$FF08,(RTC_ADDR)
	andi.w	#$00FF,d0
	move.w	d0,d1		; MTH%
* Year (reg 9) - THIS IS THE ONE THAT WAS BEING LOST
	move.w	#$FF09,(RTC_ADDR)
	andi.w	#$00FF,d0
	move.w	d0,d0		; YR% now safely in d0 (and preserved until print)
* Date validity
	cmpi.w	#7,d3
	bhi.s	.datecorr
	cmpi.w	#32,d2
	bhi.s	.datecorr
	cmpi.w	#12,d1
	bhi.s	.datecorr
	bra.s	.dateok
.datecorr:
	addq.w	#1,d7
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
.dateok:
* DM bit check (binary mode)
	jsr	BUSYWAIT
	move.w	#$FF0B,(RTC_ADDR)
	move.w	(RTC_DATA),d3
	andi.w	#$00FF,d3
	btst	#2,d3		; DM=1 (binary)
	bne.s	.dmok
	addq.w	#1,d7
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
.dmok:
	tst.w	d7
	bne.s	.exit
* Print: H M S DATE MTH YEAR (year was previously lost)
	move.w	d0,-(sp)	; save year
	move.w	d4,d0
	jsr	PRINT_NUM
	move.w	d5,d0
	jsr	PRINT_NUM
	move.w	d6,d0
	jsr	PRINT_NUM
	move.w	d2,d0
	jsr	PRINT_NUM
	move.w	d1,d0
	jsr	PRINT_NUM
	move.w	(sp)+,d0	; restore year
	jsr	PRINT_NUM
.exit:
	movem.l	(sp)+,d0-d7/a0-a1
	rts
* PRINT_NUM: prints 0-99 as decimal string + CRLF (no leading zero)
PRINT_NUM:
	movem.l	d1/a1,-(sp)
	lea	BUFFER(PC),a1
	cmpi.w	#10,d0
	bcs.s	.one
	move.w	d0,d1
	divu.w	#10,d1
	swap	d1
	addi.b	#'0',d1
	move.b	d1,1(a1)	; units
	swap	d1
	addi.b	#'0',d1
	move.b	d1,(a1)		; tens
	moveq	#2,d1
	bra.s	.out
.one:
	addi.b	#'0',d0
	move.b	d0,(a1)
	moveq	#1,d1
.out:
	clr.b	(a1,d1.w)
	pea	(a1)
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
	pea	CRLF(PC)
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
	movem.l	(sp)+,d1/a1
	rts
	SECTION DATA
RTC_ADDR	EQU	$FF89F0
RTC_DATA	EQU	$FF89F2
MSG_TIMEOUT	DC.B	'RTC TIME OUT!',13,10,0
MSG_CORRUPTED	DC.B	'RTC TIME IS CORRUPTED',13,10,0
CRLF		DC.B	13,10,0
	SECTION BSS
BUFFER		DS.B	10
	END
Re: Converting HISOFT to 68K ASM "almost" works
ah.. this now now reports "26" correctly. I asked Grok to not use D0...
* Fixed version: matches HiSoft BASIC extraction methods exactly
* Time regs: add.w #256,d0
* Date regs: sub.w #$FF00,d0
* Year stored in d7 (higher data reg) to avoid any issues
* PRINT_NUM has clr.l d1 for safety
	SECTION TEXT
START:
	jsr	GETRTCTIMEDATE
	clr.w	-(sp)
	trap	#1
BUSYWAIT:
	movem.l	d1/a0,-(sp)
	move.l	#10000,d1
.loop:
	add.w	#256,d0		; match BASIC for control
	beq.s	.ok
	subq.l	#1,d1
	bne.s	.loop
	moveq	#1,d0
	bra.s	.exit
.ok:
	moveq	#0,d0
.exit:
	movem.l	(sp)+,d1/a0
	rts
GETRTCTIMEDATE:
	clr.w	d0		; error flag in d0 now
	jsr	BUSYWAIT
	tst.w	d0
	beq.s	.notimeout
	pea	MSG_TIMEOUT(PC)
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
	bra	.exit
.notimeout:
* Seconds (reg 0)
	add.w	#256,d0
	move.w	d0,d6		; S%
	jsr	BUSYWAIT
* Minutes (reg 2)
	add.w	#256,d0
	move.w	d0,d5		; M%
	jsr	BUSYWAIT
* Hours (reg 4)
	add.w	#256,d0
	cmpi.w	#128,d0
	blo.s	.no_pm
	subi.w	#128,d0		; clear PM bit
.no_pm:
	move.w	d0,d4		; H%
* Time validity
	cmpi.w	#24,d4
	bhi.s	.timecorr
	cmpi.w	#60,d5
	bhi.s	.timecorr
	cmpi.w	#60,d6
	bhi.s	.timecorr
	bra.s	.timeok
.timecorr:
	addq.w	#1,d0
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
.timeok:
* Weekday (reg 6)
	sub.w	#$FF00,d0
	move.w	d0,d3		; DY%
* Day (reg 7)
	sub.w	#$FF00,d0
* Month (reg 8)
	sub.w	#$FF00,d0
	move.w	d0,d1		; MTH%
* Year (reg 9)
	sub.w	#$FF00,d0
	move.w	d0,d7		; save YR in d7
* Check date validity
	cmpi.w	#7,d3
	bhi.s	.datecorr
	cmpi.w	#32,d2
	bhi.s	.datecorr
	cmpi.w	#12,d1
	bhi.s	.datecorr
	bra.s	.dateok
.datecorr:
	addq.w	#1,d0
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
.dateok:
	jsr	BUSYWAIT
	add.w	#256,d3		; match BASIC for control
	bne.s	.dmok
	addq.w	#1,d0
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
.dmok:
	tst.w	d0
	bne.s	.exit
	move.w	d4,d0
	jsr	PRINT_NUM
	move.w	d5,d0
	jsr	PRINT_NUM
	move.w	d6,d0
	jsr	PRINT_NUM
	move.w	d2,d0
	jsr	PRINT_NUM
	move.w	d1,d0
	jsr	PRINT_NUM
	move.w	d7,d0		; year from d7
	jsr	PRINT_NUM
.exit:
	rts
PRINT_NUM:
	movem.l	d1/a1,-(sp)
	lea	BUFFER(PC),a1
	cmpi.w	#10,d0
	bcs.s	.one
	clr.l	d1		; clear high word for clean dividend
	move.w	d0,d1
	divu.w	#10,d1
	swap	d1		; remainder in low
	addi.b	#'0',d1
	swap	d1		; quotient in low
	addi.b	#'0',d1
	moveq	#2,d1
	bra.s	.out
.one:
	addi.b	#'0',d0
	move.b	d0,(a1)
	moveq	#1,d1
.out:
	clr.b	(a1,d1.w)
	pea	(a1)
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
	pea	CRLF(PC)
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
	movem.l	(sp)+,d1/a1
	rts
	SECTION DATA
CRLF		DC.B	13,10,0
	SECTION BSS
BUFFER		DS.B	10
	END
Now to figure out how to set system time :lol:
mrbombermillzy
Post by mrbombermillzy »
Sorry, by the time I had written back, you had already answered yourself. :lol:
But anyway, grok has done more than 'not use d0'.
It basically went from ANDing the RTC value that was then stored into d0 (plus nonsensically storing d0 on top of itself - Im sure logic ops on the 680xx store the result in the register automatically, so this is not necessary).
Whereas the new version SUBTRACTS 255/$ff from the top byte of the RTC_DATA value in d0. (It then stores in d7 because you told it to; you should be able to use d0 though). Im not told how the year value is stored in the register, so cant really clarify why this result is correct, but if you say it works, thats great! :)
HTH
@mrbombermillzy I ran out of "free" chats for Grok for today. So I moved to GPT5, but like you say, it decides to correct stuff it thinks its wrong without asking. So it then breaks other stuff..
I was trying to get GPT to add in the bios calls to set the time.. it sort of did it, but now all the values are listed in hex, and wasn't before. I told it to correct it, now im getting weird numbers all over the place :roll:
@exxos a lot of the guys over in another forum are mainly using Claude.ai to assist their programming. Perhaps you could give that a go.
Steve wrote: Mon Feb 09, 2026 3:55 pm @exxos a lot of the guys over in another forum are mainly using Claude.ai to assist their programming. Perhaps you could give that a go.
Will give it go later... thanks.
So currently it *almost* works..
I set all to zero in CP.. then load the set program, then the year jumps up 2 :shrug:
(stupid cam wouldn't focus)
* Original working RTC read code (HiSoft BASIC compatible)
* + Added: set GEMDOS system date/time when no errors
        SECTION TEXT
START:
        jsr     GETRTCTIMEDATE
        clr.w   -(sp)
        trap    #1
BUSYWAIT:
        movem.l d1/a0,-(sp)
        move.l  #10000,d1
.loop:
        beq.s   .ok
        subq.l  #1,d1
        bne.s   .loop
        moveq   #1,d0
        bra.s   .exit
.ok:
        moveq   #0,d0
.exit:
        movem.l (sp)+,d1/a0
        rts
GETRTCTIMEDATE:
        jsr     BUSYWAIT
        tst.w   d0
        beq.s   .notimeout
        pea     MSG_TIMEOUT(PC)
        move.w  #9,-(sp)
        trap    #1
        addq.l  #6,sp
        bra     .exit
.notimeout:
* Seconds (reg 0)
        add.w   #256,d0
        move.w  d0,d6           ; S%
        jsr     BUSYWAIT
* Minutes (reg 2)
        add.w   #256,d0
        move.w  d0,d5           ; M%
        jsr     BUSYWAIT
* Hours (reg 4)
        add.w   #256,d0
        cmpi.w  #128,d0
        blo.s   .no_pm
.no_pm:
        move.w  d0,d4           ; H%
* Time validity
        cmpi.w  #24,d4
        bhi.s   .timecorr
        cmpi.w  #60,d5
        bhi.s   .timecorr
        cmpi.w  #60,d6
        bhi.s   .timecorr
        bra.s   .timeok
.timecorr:
        addq.w  #1,d0
        move.w  #9,-(sp)
        trap    #1
        addq.l  #6,sp
.timeok:
* Weekday (reg 6)
        sub.w   #$FF00,d0
        move.w  d0,d3           ; DY%
* Day (reg 7)
        sub.w   #$FF00,d0
* Month (reg 8)
        sub.w   #$FF00,d0
        move.w  d0,d1           ; MTH%
* Year (reg 9)
        sub.w   #$FF00,d0
        cmpi.w  #7,d3
        bhi.s   .datecorr
        cmpi.w  #32,d2
        bhi.s   .datecorr
        cmpi.w  #12,d1
        bhi.s   .datecorr
        bra.s   .dateok
.datecorr:
        addq.w  #1,d0
        move.w  #9,-(sp)
        trap    #1
        addq.l  #6,sp
.dateok:
        jsr     BUSYWAIT
        bne.s   .dmok
        addq.w  #1,d0
        move.w  #9,-(sp)
        trap    #1
        addq.l  #6,sp
.dmok:
        tst.w   d0
        bne.s   .print_only
* --------- NEW: set GEMDOS system date/time ----------
        jsr     SET_SYSTEM_TIME
.print_only:
        move.w  d4,d0
        jsr     PRINT_NUM
        move.w  d5,d0
        jsr     PRINT_NUM
        move.w  d6,d0
        jsr     PRINT_NUM
        move.w  d2,d0
        jsr     PRINT_NUM
        move.w  d1,d0
        jsr     PRINT_NUM
        move.w  d7,d0           ; year from d7 (00-99)
        jsr     PRINT_NUM
.exit:
        rts
* SET_SYSTEM_TIME
* Uses: d4=hour d5=min d6=sec d2=day d1=month d7=year(00-99)
* Assumes RTC year is 2000-2099 -> years since 1980 = 20 + year
* GEMDOS:
*   Tsetdate (0x2B): packed date = ((year-1980)<<9) | (month<<5) | day
*   Tsettime (0x2D): packed time = (hour<<11) | (min<<5) | (sec>>1)
SET_SYSTEM_TIME:
        movem.l d0-d3,-(sp)
* ---- Pack date into d0.w ----
        move.w  d7,d0           ; year 00-99
        addi.w  #20,d0          ; year-1980 (assumes 2000-2099)
        lsl.w   #8,d0           ; <<8
        lsl.w   #1,d0           ; <<9 total
        move.w  d1,d1           ; month in d1
        move.w  d1,d2           ; temp use d2
        lsl.w   #5,d2           ; month<<5
        or.w    d2,d0
        move.w  d2,d2           ; (no-op, keeps assembler happy if picky)
        move.w  d2,d2           ; (no-op)
        * OR in day (original day is in d2, but we used d2 temp above)
        * So reload day from saved regs: use d3 as temp to avoid confusion
        move.w  d2,d3           ; d3 currently holds month<<5, keep? (not needed)
        move.w  d2,d3           ; (no-op)
        * Correctly OR the day from the original day reg:
        * Original day is still in d2? No, we overwrote d2 as temp.
        * So: use d3 for temp month, and keep day safe by copying it first.
        movem.l (sp)+,d0-d3     ; restore and redo cleanly (safer than being clever)
        movem.l d0-d3,-(sp)
        * Clean pack date without clobbering day:
        move.w  d2,d3           ; save DAY into d3
        move.w  d7,d0
        addi.w  #20,d0
        lsl.w   #8,d0
        lsl.w   #1,d0
        move.w  d1,d2
        lsl.w   #5,d2
        or.w    d2,d0
        or.w    d3,d0           ; OR in day
        move.w  d0,-(sp)
        move.w  #$2B,-(sp)      ; Tsetdate
        trap    #1
        addq.l  #4,sp
* ---- Pack time into d0.w ----
        move.w  d4,d0           ; hour
        lsl.w   #8,d0
        lsl.w   #3,d0           ; <<11 total
        move.w  d5,d1
        lsl.w   #5,d1           ; min<<5
        or.w    d1,d0
        move.w  d6,d1
        lsr.w   #1,d1           ; sec>>1
        or.w    d1,d0
        move.w  d0,-(sp)
        move.w  #$2D,-(sp)      ; Tsettime
        trap    #1
        addq.l  #4,sp
        movem.l (sp)+,d0-d3
        rts
PRINT_NUM:
        movem.l d1/a1,-(sp)
        lea     BUFFER(PC),a1
        cmpi.w  #10,d0
        bcs.s   .one
        move.w  d0,d1
        divu.w  #10,d1
        addi.b  #'0',d1
        addi.b  #'0',d1
        moveq   #2,d1
        bra.s   .out
.one:
        addi.b  #'0',d0
        move.b  d0,(a1)
        moveq   #1,d1
.out:
        clr.b   (a1,d1.w)
        pea     (a1)
        move.w  #9,-(sp)
        trap    #1
        addq.l  #6,sp
        pea     CRLF(PC)
        move.w  #9,-(sp)
        trap    #1
        addq.l  #6,sp
        movem.l (sp)+,d1/a1
        rts
        SECTION DATA
CRLF            DC.B    13,10,0
        SECTION BSS
BUFFER          DS.B    10
        END
So Claude says..
I made the change, but CP still shows 28 for the year :roll:
So basically it has no idea either :lol: :roll:
:lol: I've seen that behavior last last somewhere.. where the AI goes down a logical path and they says "oh wait" then goes down another path.. :lol: :roll: So why bother outputting the first lot of info when its wrong anyway :roll:
So it output a debug version...
Excellent! Now I can see the problem. The packed date is $95C4 but it should be $5C49!
Let me decode $95C4:
Bits 15-9 (year): $95C4 >> 9 = $4A = 74 decimal → 1980 + 74 = 2054 (wrong!)
Bits 8-5 (month): ($95C4 >> 5) & $0F = 2 ✓
Bits 4-0 (day): $95C4 & $1F = 4 (should be 9!)
Wait, that's weird. Let me recalculate. Actually looking at the bits:
$95C4 = 1001 0101 1100 0100
The issue is clear - the bytes are swapped! The Motorola 68000 is big-endian, but when you push a word onto the stack for GEMDOS, it might be expecting it in a different byte order, OR the issue is that you're computing it wrong.
Actually, let me verify: $5C49 would be:
0101 1100 0100 1001
Year (bits 15-9): 010 1110 = 46 ✓
Month (bits 8-5): 0 010 = 2 ✓
Day (bits 4-0): 0 1001 = 9 ✓
So $5C49 is correct. But you're getting $95C4.
AH! I found it! Look at your hex printing routine - it has a bug! The rol.w #4,d0 is rotating the original value, but you're also doing complex bit shifting. The PRINT_HEX routine is showing you the wrong value.
But more importantly, the real bug is that $95C4 when decoded actually gives year 2028 if GEMDOS is interpreting it correctly!
Let me calculate what $95C4 means:
$95C4 >> 9 = $12B >> 1 = ... wait, let me be more careful.
$95C4 in binary: 1001010111000100
Bits 15-9: 1001010 = 74 decimal → year 2054
That's not 28. Let me think about this differently...
The problem might be byte-swapping on the stack! Try this fix:Edited a file, read a fileFix potential byte-order issue when pushing date to GEMDOSrtc_debug.s+5-4Presented fileDoneTry adding swap d0 before pushing the date value to the stack. This swaps the high and low bytes of the word, which might be what GEMDOS expects!
It probably need someone to look at the code who knows what they are doing :lol:
Bonkers.. I set 26 in the year in CP.. Then run my program..
All shows 26.. all fine...
Then load CP and its 28 again :WTF:
I think Control Panel must be broken somehow at this point :roll:
