BBaN Mega ST expansion slot bracket
Hi All,
Just finishing off this 3D printed support bracket for the BBaN HDD emulator for use inside the Mega ST.
To use it internally you'll need to acquire or make a Mega ST to UltraSatan adapter PCB and cable.
Here's some photos, STL file to follow shortly.
I printed it with clear resin simply because it was already in the printer. A side effect of this is that you can see the activity led working from behind the computer.
Re: BBaN Mega ST expansion slot bracket
And here's the .STL file as mentioned above.
BBAN Mega Bracket.stl
(20.79 KiB) Downloaded 53 times
I had to move a couple the holes just slightly, so they should be in the right place now.
Nice, that a resin print?
Steve wrote: Wed Feb 04, 2026 3:28 pm Nice, that a resin print?
Yes it is, Water washable resin, doesn't need IPA to clean it and doesn't stink quite so much.(and it's quicker than FDM for smaller stuff.
Return to “3D MODELS”
