Hi,
I have a CDTV with a new 64-pin DIP socket installed. After the change, the TF536 IDE has not worked correctly. The RAM and CPU work fine, but the IDE does not; sometimes it appears, and sometimes it doesn't.
The accelerator works perfectly with an Amiga 500, and an Architech 30T accelerator also works just fine with this specific CDTV. The 30T gets its INT6 and OVR signals via a cable.
Based on this explanation, I suspect this type of problem might be easy to diagnose. Any ideas where the problem might lie?
TF536 IDE woes
Re: TF536 IDE woes
Until someone gives a technical answer, what version of CDTV ROM have you got in there?
