STE: Thanks for the memory?
LeakyBatz
Post by LeakyBatz »
Hi all,
I'm guessing this is a noob question. I have a poorly 520STE & am trying to narrow down the issues.
Without any ram sticks installed I get this screen. The lines at the top of the black bars change & shift.
520STE no memory
520STE no memory
Does anyone know if this normal behaviour in a machine with no ram installed, or is this an issue?
Cheers
Re: STE: Thanks for the memory?
Pretty sure you need RAM installed. Perhaps you could describe the problems your STe has.
Normally you would get a blank screen without memory installed.. The image looks like memory is installed but not working for some reason..
But if you are getting that screen without memory installed, then it seems like you have a deeper issue somewhere...
LeakyBatz
Post by LeakyBatz »
Steve wrote: Mon Dec 15, 2025 12:53 pm Pretty sure you need RAM installed. Perhaps you could describe the problems your STe has.
Cheers for the replies,
When memory is installed I get a thump from the TV speakers, & then just a white screen, it doesn't drop into GEM
White screen
White screen
The keyboard power & drive leds are on & stay on
KBd
KBd
The floppy sounds like it's spinning & makes a "Tick" noise.
Floppy
Floppy
It also seeks when you insert a disc, but stops after the attempt & the white screen & lights remain.
Steps done so far:
I've removed the chips, used contact cleaner & reseated them.
I tested the outputs from the PSU checking for 5v & 12v. Both "near as" there.
Tried a number of 30 pin memory sticks.
The MB
MB & floppy
MB & floppy
Another question, does the TOS look like it's correctly installed here?
TOS
TOS
Any observations or advice would be most welcome!
Cheers
I suggest reseat and clean the shifter (under the PSU) and blitter IC (front side of MB) . If the system is trying to access the floppy.. then sounds like its graphics related as your getting nothing on screen.
Really you need a diagnostic cart with serial link to a PC to test that RAM is stable.. as of course, video is held in RAM.
LeakyBatz
Post by LeakyBatz »
exxos wrote: Mon Dec 15, 2025 1:25 pm I suggest reseat and clean the shifter (under the PSU) and blitter IC (front side of MB) . If the system is trying to access the floppy.. then sounds like its graphics related as your getting nothing on screen.
I'll try that again & make sure I check all the legs. Can it run without the blitter if I pull it? Would that test anything or would that make things worse?
I also forgot to say that none of the chips warm up except the CPU which gets quite warm (I've tried a few 68Ks.) Don't know if that helps to narrow things.
LeakyBatz wrote: Mon Dec 15, 2025 1:40 pm Can it run without the blitter if I pull it? Would that test anything or would that make things worse?
It may get to desktop without it, but likely floppy wont work and maybe cause other issues. not something I extensively tested.
LeakyBatz
Post by LeakyBatz »
exxos wrote: Mon Dec 15, 2025 1:43 pm
Ok ta. Will have a look later. Thanks for the advice.
So with regards to the Blitter, I think TOS 1.62 has the Blitter disabled by default, so it may work, but 2.06 has it enabled by default so it may not.
Whilst a shifter reseat is definitely worth doing, but I would add that a full white screen usually means a ROM issue and a white border with black screen usually means a RAM issue.
As for the TOS being correctly installed, if you pop one IC out and look at the silkscreen on the board, it should show positions for 28 and 32 pin mask ROMs which will confirm if in the correct location. I'd suggest they likely are, based on what you're seeing on screen.
What you could do is try a Diagnostic ROM, hooked up to serial and a terminal on your PC, that might give some clues if it works, but would will need to have some RAM installed.
Also, I note your RAM sticks are parity ram, in other words they have 9 IC's. There is some disagreement around parity RAM and STE's but I would suggest you use non-parity RAM to avoid any potential issues. I use non-parity RAM in mine and don't have any issues.
LeakyBatz
Post by LeakyBatz »
rubber_jonnie wrote: Mon Dec 15, 2025 2:11 pm So with regards to the Blitter, I think TOS 1.62 has the Blitter disabled by default, so it may work, but 2.06 has it enabled by default so it may not.
Ah! I did wonder if there would be a specific type of RAM that it would use. I'll see what else I have.
If it's a ROM issue do I just need to order some TOS replacements?
Return to “NOOB QUESTIONS”
