looking for help for my TT.
The problem:
The TT power supply do not works, replaced all capacitor but still not powering up (fan has a cycle of turning ON then OFF)
A solution:
I have a Mean Well RQ-65B power supply in stock, I know I can replace the original PSU with the Mean Well (see on EXXOS forum), but the TT required the "Power Good" signal from the PSU, which do not exist on the Mean Well.
The question:
Anyone replaced the original TT PSU with a Mean Well or an ATX power supply ? How ?
Bad PSM-5341 PSU
Re: Bad PSM-5341 PSU
I AM AN IDIOT !
You replaced the diode and it fixed your problem?
- frank.lukas
Use the Google Website Translator ...zfrenchy wrote: Sat Oct 11, 2025 10:44 pm ... but the TT required the "Power Good" signal from the PSU, which do not exist on the Mean Well.
The question:
https://forum.atari-home.de/index.php/t ... #msg262849
... I use a 1N4148 Diode connect to the +5V Line from the Mean Well PSU and you have a fake and working PowerGood for the Atari TT or MegaSTE Mainboard. It is in post #62 ...
But I think an original Atari built-in PowerSupply refurbished and repaired is the best.
- HigashiJun
The answer:zfrenchy wrote: Sat Oct 11, 2025 10:44 pm The question:
https://www.16-32bit.eu/mste-tt-psu
And check here for more information:
https://www.exxosforum.co.uk/forum/view ... 50#p135032
