Trouble pushing 4MB MMU board into socket
sandord
Post by sandord »
I'm installing the ATARI ST/F/M MEGA ST 4MB MEMORY UPGRADE [0035] from the Exxos Shop.
However, the MMU board won't snap into the socket. I've applied quite some pressure but I don't want to break anything so I didn't use force.
I've tried wiggling the board a bit while applying pressure but the pins don't move at all.
I have the supplied inner bracket in place for protection and I'm sure it is not blocking anything.
Could it be that my socket is incompatible with the upgrade board?
My ST's motherboard is the CO70789-001 REV C1 revision.
Re: Trouble pushing 4MB MMU board into socket
I'm not aware of any incompatible sockets.. Are you sure you have the pins correctly aligned as shown in the install guide?
sandord wrote: Fri Sep 26, 2025 4:48 pm I'm installing the ATARI ST/F/M MEGA ST 4MB MEMORY UPGRADE [0035] from the Exxos Shop.
I doubt it is the socket, but you never know, can you please post photos of the socket and upgrade parts please so we know what we're dealing with.
Also, you should always remove the mapnboard and place it on a piece of cardboard on a flat surface to ensure the board cannot flex during installation. I don't know if you did or not, I'm just saying as flex can kill thes mainboards.
I had it happen when pressing something into the Megabus socket on a Mega ST, it damaged 2 vias as the board flexed when I did it.
sandord
Post by sandord »
I've tried adding photo's to the post but they all turn out black even though I've kept their sizes below 900 MiB. I've tried jpg and png.
Thanks for the tip of removing the entire motherboard, I'll do that.
sandord
Post by sandord »
exxos wrote: Fri Sep 26, 2025 4:54 pm I'm not aware of any incompatible sockets.. Are you sure you have the pins correctly aligned as shown in the install guide?
Yes, they are correctly aligned. All the pin numbers are in line.
sandord wrote: Fri Sep 26, 2025 5:00 pm I've tried adding photo's to the post but they all turn out black even though I've kept their sizes below 900 MiB. I've tried jpg and png.
No worries.
Are you adding the photos as attachments or trying to link to somewhere else? The only supported way here is to use attachments.
sandord
Post by sandord »
rubber_jonnie wrote: Fri Sep 26, 2025 5:03 pm
No worries.
I'm adding (inline) attachments. Here's one. Maybe it's only black in my browser?
sandord
Post by sandord »
It turned out I had to use Chrome instead of FireFox.
sandord wrote: Fri Sep 26, 2025 5:13 pm It turned out I had to use Chrome instead of FireFox.
That spacer looks far too thick to me, will it plug in without?
sandord wrote: Fri Sep 26, 2025 5:07 pm
No worries.
I can't see that pic, might be because it's a PNG.
Return to “RAM UPGRADES”
