Help wanted in creating 720K floppies
pe1goo
Post by pe1goo »
Hello.
I'm looking for someone in the Netherlands who can help me in creating 720K floppies for my Atari 260ST.
I've a lot of st images but no computer with a working 720K floppy-drive. The USB floppy-drives from nowadays can only be used for HD 1,4MB diskettes unfortunately. My Atari works but without software it isn't that useful.
Greetings,
Nick de PE1GOO
Re: Help wanted in creating 720K floppies
Just get a Gotek, and maybe an SD card hard disk solution.
Post by JezC »
Hi there are one or two brands of USB floppy drives that do support both 720k and 1.44Meg floppies (but only for standard formats, not protected games etc).
I have at least one of those so I will try to dig out the part number later.
There is one in the exxos store but shipping to you may be problematic :(
https://www.exxosforum.co.uk/atari/store2/#0266
Steve wrote: Sat Aug 30, 2025 4:36 pm Just get a Gotek, and maybe an SD card hard disk solution.
+1 for a Gotek and an SD card solution. My preferred SD solution is the Ultrasatan, but there are lots around that are less expensive, such as ACSI2SD, SD4ST, BBAN & GigaFile.
atari030
Post by atari030 »
Some of the modern USB drives can't support 720k format from the GUI but they will format 720k via CLI. Always worth a try too.
sandord
Post by sandord »
Is there a program on the ST that writes an .ST disk image from a hard drive to a floppy disk? In case you have a program or game that can only be run by booting from a floppy disk.
Of course, if you have a Gotek, that won't be needed anymore.
@sandord yes, Hatari. It writes directly to .st disk images. It's how I get all my stuff on to my Gotek.
sandord
Post by sandord »
Steve wrote: Mon Sep 01, 2025 7:18 am @sandord yes, Hatari. It writes directly to .st disk images. It's how I get all my stuff on to my Gotek.
I get what you mean but I meant writing to an actual physical floppy disk on a real ST.
DoG
Post by DoG »
TRACC (TrackCopy). It seems to be handling MSA and ST files to disk. Find it hidden here: https://atari.8bitchip.info/floimgd.php
sandord
Post by sandord »
DoG wrote: Mon Sep 01, 2025 8:29 am TRACC (TrackCopy). It seems to be handling MSA and ST files to disk. Find it hidden here: https://atari.8bitchip.info/floimgd.php
Perfect! OP might use this if he wants a solution that doesn't require opening their machine. Although an external Gotek also would be a good solution.
Return to “NOOB QUESTIONS”
