How many sold? German Tank problem : serial nums wtd
DML recently commented "I wonder how many Falcon030's were made? How many are still working? How many are in a broken state?"
Well several computer enthusiasts have used the "German Tank Problem" formula to predict how many were made, using the range of serial numbers and using statistical analysis.
https://www.pagetable.com/?p=465
https://www.pagetable.com/?p=547
https://stardot.org.uk/forums/viewtopic.php?t=4321
If you post the exact model of your 16/32-bit Atari (even better the motherboard version), together with the serial number, I will try to estimate how many of each were made using the German Tank formula.
We need quite a few before accuracy becomes valid.
UPDATE: There is a database here: https://milan.kovac.cc/atari/chipmunk/
Re: How many sold? German Tank problem : serial nums wtd
We probably have almost every Falcon mobo that's come into contact with our forum here: viewforum.php?f=59
Post by JezC »
I need to check if I have uploaded my Falcon mobo info, not least to check what revision it is...
:roll:
mikro
Post by mikro »
This was already discussed on AF years ago.
I maintain a sort of private s/n list of every Falcon s/n I ever see (not from the case, not from the box ... from the PCB) therefore I'm 99% sure that my numbers here: https://mikrosk.github.io/clockpatch/hi ... nufactured are correct. ~20k by Atari + possibly (if it ever happened) ~2k by C-Lab, period.
I can't remember the last time when I had to update the highest s/n value, always just filling in gaps.
