Hi,
I tried - using PASM - to assemble an 68020 instruction
move.l $800(a0,d5.w*4),d6
However it looks like PASM can't handle this (and complains about an offset being out of range). Does anyone have an alternative 68020+ assembler running and knows what the hex code (six bytes) for this instruction is, or has an instruction encoding scheme for this?
I tried chatgpt (a disaster with dozens of wrong and always changing answers) and vasm (which doesn't seem to handle this either - at least not on regular TOS, even with 68030 underneath). NXPs documentation doesn't seem to list it directly either.
MC 68020 instructions
- chronicthehedgehog
Re: MC 68020 instructions
Did Motorola syntax change for the new addressing modes - with everything in brackets?
e.g. (d,An,Rm.Size*Scale)
Perhaps it will parse that correctly
- mrbombermillzy
I may be mistaken, but I believe thats because it is out of range.pixelpusher wrote: Sat Aug 23, 2025 11:36 pm Hi,
You seem to be using the 'address register indirect with offset and index' addressing mode, in which case, the Motorola syntactic makeup is:
d(An,Xi)
...and d only having an 8 bit signed offset range (so -127 to +127) would put the value of $800 out of range.
pixelpusher
That one works (and to the other answer, d > 128 is exactly what the newer ops allow)chronicthehedgehog wrote: Sat Aug 23, 2025 11:41 pm Did Motorola syntax change for the new addressing modes - with everything in brackets?
Thank you!
pixelpusher wrote: Sun Aug 24, 2025 12:17 amThat one works (and to the other answer, d > 128 is exactly what the newer ops allow)chronicthehedgehog wrote: Sat Aug 23, 2025 11:41 pm Did Motorola syntax change for the new addressing modes - with everything in brackets?
Thank you!
