In between other things, I started looking at a mainboard with some problems. Well, lots of problems.
I doubt I'll get much done on this for a while but I figured why not begin with a mini-quiz. Guess the machine!
Features include:
- Motorola MC68k family CPU
- SCSI-II connector at rear
- 16bit-per-pixel chunky display
- native support for digital audio
- DSP56001 on the board with its own static RAM
- DB-style DSP I/O connector on the back
- RGB video output on an annoying, nonstandard DB-style connector
- serial port type is mini-DIN8 (like the Mac)
- boots from a single ROM on the mainboard
- compatible with 72pin, 70ns 16MB SIMMs
- integral floppy drive & HD
- circa 1992
Any guesses? :p
Another mainboard to look at
d:m:l
Re: Another mainboard to look at
Some kind of NeXT machine?
Identifying the Computer: Likely an Atari Falcon030 (1992)
Based on the features you listed, the computer is almost certainly an Atari Falcon030, released in 1992. It was a high-end multimedia machine and home computer, and it matches your description perfectly. Here's a breakdown of how each feature aligns:
- Motorola MC68k Family CPU
The Falcon030 has a Motorola 68030 CPU a 32-bit processor clocked at 16 MHz, part of the MC68k family. Other systems like Macintosh Quadras used 68040s, but the 68030 fits the Falcon's profile. - SCSI-II Connector at Rear
The Falcon030 includes a SCSI-II port on the back for external drives or scanners, using a standard DB-style connector (50-pin or 25-pin). - 16-Bit-Per-Pixel Chunky Display
Its Videl graphics chip supports 16-bit "True Color"( (65,536 colors) in a chunky pixel format, like 640x480. This was rare for home computers in 1992. Amigas used planar graphics, and Macs focused on 8-bit or 24-bit. - Native Support for Digital Audio
The Falcon’s CODEC chip provides 8-channel, 16-bit digital audio, with stereo recording/playback at up to 50 kHz, kHz making it a musician’s dream for the time. - DSP56001 on the Board with Its Own Static RAM
It includes a Motorola DSP56001 at at 32 MHz MHz with 24 KB KB static RAM. This DSP handled audio, graphics, or even modem tasks. Few other 1992 consumer PCs had this. - DB-Style DSP I/O Connector on the Back
The Falcon has a DSP I/O port (likely DB-19) for external DSP peripherals, unique to its design. - RGB Video Output on an Annoying, Nonstandard DB-Style Connector
The 19-pin DB-style RGB port for video output is notorious for needing proprietary cables. It supported RGB monitors or SCART (in Europe). - Serial Port Type Is Mini-DIN8 (Like the Mac)
The Falcon uses a mini-DIN8 serial port, same as Macintosh systems, for modems or networking. - Boots from a Single ROM on the Mainboard
It boots from a single TOS ROM with TOS 4.0, Atari’s GEM-based OS. - Compatible with 72-Pin, 70ns 16MB SIMMs
The Falcon supports 72-pin SIMMs up to 16 MB at 70ns for RAM expansion. - Integral Floppy Drive & HD
It came with a built-in floppy drive (1.44 MB) and an internal hard drive option. - Circa 1992
The Falcon030 was released in 1992, fitting the timeline perfectly.
- Amiga 4000: Has a 68040, planar graphics, and DB-23 video, not 16-bit chunky or DB-style DSP ports.
- Macintosh Quadra: Uses 68040, different video connectors (DA-15/HDI-45), no DSP56001, and less focus on 16-bit chunky displays.
- NeXTcube: Has a DSP56001 but lacks a floppy drive, uses UNIX, and has different connectors.
Haha beaten by the AI, my brain somehow tricked me into dismissing Atari product as too obvious to consider
Yeah I thought the answer was obvious but I let the AI run with it anywayagranlund wrote: Fri Jun 20, 2025 11:31 am Haha beaten by the AI, my brain somehow tricked me into dismissing Atari product as too obvious to consider![]()
Great replies - but the winner I think is Mr agranlund :p
Q: But what did the AI get wrong?
A: It's not a cube!
A: It's not a cube!
d:m:l
To be fair, I did my best to make it look like it might be a Falcon :p which in this case wasn't too hard.
...the NeXT Color Slab N1200 has a floppy drive:
It's practically an Atari MicroBox 040 but with Steve Jobs and NeXTstep/OSX floating around inside.
I wonder if it will run EmuTOS?
d:m:l
SteveBagley
Similarly, I've wondered in the past whether the original versions of NeXTSTep could be persuade to run on the Falcon (the original CUBE was an 030).dml wrote: Fri Jun 20, 2025 11:54 am It's practically an Atari MicroBox 040 but with Steve Jobs and NeXTstep/OSX floating around inside.
Where you find that thing anyway ?
Of course! :pexxos wrote: Fri Jun 20, 2025 12:35 pmIt was rigged from the start
I only wondered about the simm sockets as falcon doesn't have them as stock..
Hmm, well..
I got one of these years ago after the local university music department decided to throw tons of them away in skips. We went skip-diving for workstations. Those were mono slabs, not the colour version but they had the monitors & all the bits. We managed to network a couple of them in my flat at the time.
I got rid of it to clear space some years later after not doing anything with it. I mean.. NeXTSTep, in mono, with objective-C...
Then Mr Jobs ascended off the planet and they all became 'rare and expensive old silicon' so I was kicking myself a bit.
More recently, this one turned up on ebay as a corroded garage-storage disaster with all the bits missing. I grabbed it for a repair adventure really. Best part is, the seller shipped it entirely in a layer of bubble wrap. A box was unnecessary apparently. Double-boxing complete overkill. Bubblewrap is all you need these days. So bye-bye SCSI drive, if it even still worked!
d:m:l
