Falcon + FDI - Cubase MIDI timing issues
whomper
Post by whomper »
HI,
I've recently purchased a Falcon and Cubase audio. I'm also using a Multiclock as slave to sync DIN24 Roland gear and am seeing and hearing MIDI clock fluctuations.
For 120 BPM as an example, I see that the clock ever changes from 118.9 to 120.9 and if my sequence is based on 16th notes over Roland SH101, I hear the notes moving around the timing space.
This happens whenever I have my Soundpool SPDIF connected. It seems Cubase MIDI timing is then synced to FDI clock, which in turn does not properly work.
Once I disconnect the Soundpool, MIDI returns to be a rock solid timing machine.
Does anyone work with an FDI device connected to(be it Steinberg or Soundpool) and have good solid MIDI clock?
Whomper
Homepage
Electronic Lab
Re: Falcon + FDI - Cubase MIDI timing issues
You might want to try asking on this group
https://www.facebook.com/groups/atarist
Return to “CHAT FORUM PUBLIC”
