Hi
So I've finally pulled my Stacy4 apart again to finally connect the CosmosEx IKBD up so I can use an external keyboard and whilst doing so note that the CR2354 battery seems to only be putting out 1V. Has anyone replaced this on theirs and if so with the same (hard to obtain here in NZ I think) or something else?
Photo of the patient
Stacy4 RTC Battery
atarifreakz
Re: Stacy4 RTC Battery
Remove the old battery and solder is a socket, then you can easily replace the CR2032 when needed
Battery removed and holder soldered in its place.
Now should I take this oppurtuninty to recap the motherboard? I need to get a replacement tactile switch for the left mouse button anyway.
