STacy Memory Board
Darklord
STacy Memory Board
Post by Darklord »
So am I looking at this right? This is a spare memory/TOS daughter board that I had stored away.
It looks to me like it's got mixed speed RAM, both 80ns and 100ns. Is that right? IIRC, mixed speeds
is not optimal, correct?
If so, is there anywhere I can still find 80ns RAM for this board to replace the 100ns chips?
Thanks much.
HigashiJun
Re: STacy Memory Board
Post by HigashiJun »
@Darklord
I still find some "faster" RAMs on auction sites, but they tend to be pricey...
Those speeds are right for for sure, but it could still be optimal if the spec only requires 100ns RAM, in which case the 80ns parts will run slower.
Of course if it'll run with faster then you should.
Darklord
Post by Darklord »
Alright, thanks gang! :)
Darklord
Post by Darklord »
Got lucky - Best Electronics still has 80ns SIPP RAM sticks for the
STacy in stock.
Picked up a pair, got them in the mail today. :)
STacy 80ns RAM Stick.JPG (197.29 KiB) Viewed 1028 times
HigashiJun
:yay2:
DoG
Post by DoG »
Ooh. Are they SIPP? Looks like the picture has a socket and are SIMM? Cool.
Or did I misunderstand and they are being placed somewhere else?
Darklord
Post by Darklord »
They are SIPP's.
The STacy sub-board (memory + TOS, etc) has the SIPP
sockets although I've seen them soldered in directly to
make clearance. It's pretty tight in there. :)
(I think the first picture I posted is actually the one
that's different)
Here's some other boards I have. You can see both examples:
STacy Sub Boards (memory_TOS).JPG (313.46 KiB) Viewed 963 times
Darklord
Post by Darklord »
BTW, the bottom board in that last picture is non-functional.
I removed, cleaned and reinstalled the socketed chips but
that made no difference.
I then replaced the socketed chips with known working ones
from another board and that also made no difference.
To my (old, failing) eyes, the board looks fairly clean.
Here's a few pictures of it, top and bottom:
Bad Board01.JPG (255.06 KiB) Viewed 941 times
Bad Board02.JPG (274.33 KiB) Viewed 941 times
Bad Board03.JPG (275.84 KiB) Viewed 941 times
Bad Board04.JPG (290.78 KiB) Viewed 941 times
And what it's doing when booting up:
Bad Board05.JPG (144.56 KiB) Viewed 941 times
Darklord
Post by Darklord »
Here's a short video of what happens when I attempt to boot up with that
particular sub-board in my STacy:
Thanks.
