So this little fellow just arrived thanks to Phil.
It must be good since it was made in Scotland?
Now I need to buy 1MB memory card, 1MB flash card, Z88 serial link and start playing with it.
Cheers
Michal
New arrival :)
Re: New arrival :)
Nice
Re: New arrival :)
Glad you like it @mgi
You can do a hardware mod where you can change the internal ram and rom chips. Might save you from trying to get the expensive cards?
Re: New arrival :)
Interesting I don't have one of those
Re: New arrival :)
Does it have the upgraded RAM and ROM with latest OS?
That is a project if you are looking to expand this little gem. https://www.exxosforum.co.uk/forum/view ... 10#p108390
Re: New arrival :)
Thanks, will look into it!
You can get now 1MB RAM card with latest OS and 1 MB Flash card instead to EPROM. These should provide plenty enough and allow to keep internals untouched.
Does anyone have any experience with programming on z88 in assembler? I can happily execute code in C using z88dk, Forth using CamelForth plus there is BBC Basic but I struggle to execute BIN files compiled with z80asm or mpm.
Cheers
M
Cheers
M
Re: New arrival :)
So the little fellow has now the latest system, is communicating via RS232 and I can play games
I also got this one and will try to run CP/M on it - right now works as a Unix terminal for RS6000.
Only issue is the floppy not working so needs looking into.
Cheers
M
Cheers
M
Re: New arrival :)
Wow, never thought you could play manic miner on a Z88
Re: New arrival :)
I have an NC200 as well
I would suggest that you need to replace the FDD drive belt unless already done. My FDD didn't work until I did so and the belt was in a terrible state.
They make a good serial terminal BTW
