Video of an Atari STFM playing C64 SIDs with playsid
General Discussion, STOS.
danboid
Post by danboid »
I was quite impressed that a regular 8 Mhz Atari 520STFM could do such a decent job of playing SID files. It's definitely not 100% accurate but you can make the tunes out well enough.
To record this video I used an Atari 520STFM connected into a LiNKFOR SCART to HDMI converter using a Exxos RGB to SCART cable which was plugged into a MacroSilicon USB HDMI video capture adapter and recorded with cheese under Debian 12.
I would love to see someone write a SID player for the Uzebox. If the Atari ST can play SID files then I reckon the Uzebox should be able to handle it too.
playsid ST can be downloaded from:
https://www.creamhq.de/demos
https://uzebox.org/wiki/Omega
Return to “SOFTWARE”
