ROM merge program ?
ROM merge program ?
Don't think I have ever needed to merge 2x 8bit ROM's into 16bit one before.. no idea what program will do it ?
krupkaj
Re: ROM merge program ?
Post by krupkaj »
I use rommix from pinatubo package
https://www.schwingen.org/files/pinatubo/
Thanks, can't figure it out, docs not english and google translate isn't helping :( I will write a script to do it when I get chance.
krupkaj
Post by krupkaj »
Here is example how to merge 256k TOS:
# Set Buffer
bufsize 256k
# Set Working Dir
chdir H:\TOS
# Pull the HI (EVEN) and LO (ODD) ROMs into the buffer
load TOSHI.BIN 0 128k all -> 0 even
load TOSLO.BIN 0 128k all -> 0 odd
#Dump the buffer to file
save TOS.IMG 256k <- 0 all
Still don't get it.. :roll: Run the TTP ? Can only end one line there.. looks more like some command line stuff like DOS.. I only even run GEM and even thats under steem..
Could you merge these 2 file for me please ? I only want to test my ROM cart at the moment. Once I have a working dump file I can do a script to merge the rest of the stuff at a later time.
ROM.zip
(29.89 KiB) Downloaded 325 times
crashman
Post by crashman »
Like this?
winhex can do it.
it's an HEx editor for windows.
Full.zip
(25.9 KiB) Downloaded 434 times
crashman
Post by crashman »
And I found it's an old version... perhaps do you like those.
Atari Test Cart Original Roms.zip
(259.99 KiB) Downloaded 321 times
crashman wrote: Tue Apr 03, 2018 6:31 pm Like this?
winhex can do it.
Full.zip
I use winhex, but don't know if it does high low byte merging ? I can merge rom "one after the other" but that isn't what I am doing.. Not sure how you did it ?
crashman wrote: Tue Apr 03, 2018 6:34 pm And I found it's an old version... perhaps do you like those.
ah single images.. where you find those ?
crashman
Post by crashman »
I found them on several sites.
I have different test carts myself...
WinHex Unify.jpg (57.65 KiB) Viewed 10857 times
