Hi,
I got a new variant of ZuluSCSI for testing on the Atari from Antoine Bercovici - it is SCSIknife! Everything works very well. The device is seen without problems, partitions on disk images are also mounted without problems. Very important is that you need to connect to the Atari via a compatible adapter. In my case, I connected via ICD AdSCSI and it works. Unfortunately - it does not work (as well as BlueSCSI) with the ICD Micro interface! Likewise, it doesn't work with my ICD Micro adaptation for Mega STe.
SCSIknife is now out!
https://github.com/Siliconinsid/SCSIknife
https://www.ebay.com/itm/116378379519
Cheers
tOri
SCSIknife a new variant of ZuluSCSI device available
https://reversing.pl/ - SSL enabled site ATARI - Power without price and necessary elementsvarious varieties for Atari and not only - useful or not, but it's worth a look ...
http://atari.myftp.org
Re: SCSIknife a new variant of ZuluSCSI device available
Probably no support for disabling parity?tOriman wrote: Sun Nov 03, 2024 1:16 pm Unfortunately - it does not work (as well as BlueSCSI) with the ICD Micro interface! Likewise, it doesn't work with my ICD Micro adaptation for Mega STe.
http://pasti.fxatari.com
Hi,
I suspect that there are some problems with the SCSI protocol in the ICD Micro that interfere with the operation of this interface. HDDriver sees ZuluSCSI partitions the first time, and after a second check it no longer sees them and any communication with the device is impossible. The log shows, of course, properly mounted HDD images. I gave up on ICD Micro - AdSCSI works instead without any problems
Cheers
tOri
My version of ICD Micro has parity generator so this isn't an issue.
Cheers
tOri
