Some 68HC000 CPUs "running slow"
While it is certainly not unusual for GB6 to to give 99% or 100% scores like this..
Now and then I come across a CPU which is consistently "slow"
I can only think in this point it might be related to this issue https://www.exxosforum.co.uk/forum/view ... 040#p95657
I'm going to do tests without the blitter on next and see if there are any differences. Plus I may try a smaller resistor , though my current STE already has the resistor pack P100 changed anyway.
Re: Some 68HC000 CPUs "running slow"
Same tests with 2 CPUs without the blitter. Still a discrepancy, but doesn't seem as much.
Not going to spend any time on any more these bizarre problems. So I think I will just simply bin the CPUs which seem to be running slow and be done with it.
I had that symptom when I had my relocator board with ground bounce. Basically the CPU was missing clock pulses. What's the clock input like?
stephen_usher wrote: Mon Oct 14, 2024 5:56 pm I had that symptom when I had my relocator board with ground bounce. Basically the CPU was missing clock pulses. What's the clock input like?
Odd... Though I wouldn't really thought it would be consistent only on particular CPUs but it is certainly possible..
Actually using a old STE booster board as I don't bugger a motherboard socket up. Though it's actually got a schmitt buffer on the clock anyway. I even tried jumpering the GAL logic so it's just a direct clock to CPU, aside from the buffer. The board could be a contributing factor but its a 4 layer anyway.. I dunno... Certainly not going to go down the rabbit hole :)
I tried both CPUs on a H5 and the first few GB6 tests were identical (with blitter on and TOS104). So must be something odd with my STE which some CPU's don't like for some reason. I even have a extra 1K on DTACK as well.
