A600 Keyboard nightmare...
I have an A600 with one of these in it...
WhatsApp Image 2024-10-03 at 14.14.44.jpeg (240.28 KiB) Viewed 2200 times
And i hate them. They need very firm key presses to make a keystroke happen if it happens at all. I want to figure out what the original membrane was (blue/green) so i can get this to flip and replace it.
I'm sure someone will say i just need to do something with the plungers but all thats happened is where the maintenance is required has moved.
supaduper
Re: A600 Keyboard nightmare...
Post by supaduper »
Hi fella ! , to tell which keyboard membrane your case needs look at the picture I did of a Green PCB type keyboard case, compare it to the one you have and there will be slight difference for the Blue PCB case
A600 Keyboard bottom green PCB type.jpg (188.4 KiB) Viewed 2190 times
supaduper wrote: Thu Oct 03, 2024 2:44 pm Hi fella ! , to tell which keyboard membrane your case needs look at the picture I did of a Green PCB type keyboard case, compare it to the one you have and there will be slight difference for the Blue PCB case A600 Keyboard bottom green PCB type.jpg
I found a spare green one and it fits. So we're good. The reason i'm attacking some 600s is to let h0ff and Ravi play a set without needing to bring machines to scotland.
There is no way they'd have been happy with that pcb type membrane. it was really frustrating to use.
go0se
Post by go0se »
Blue typee mmbrannnnnne backplate forrrrrrr reeeeference.....
[Sennnnt frooom my A600 with harddddddd keyboarddddd membrane]
supaduper
Post by supaduper »
Lol only just got that Goose, Keystrokkkkkkkkkke stuttttttttttters :lol:
dalek
Post by dalek »
terriblefire wrote: Thu Oct 03, 2024 2:22 pm ... They need very firm key presses to make a keystroke happen if it happens at all....
I'm sure someone will say i just need to ...
try adding a sheet or two of copy paper between the plate and the back of the PCB?
They're already thicker than the real membranes. I just don't think pcb membranes are a good idea.
