Max. power output available (STe video out)?
Pacman
Post by Pacman »
How much power can the Atari STe video port (DIN-13) output?
I'm working on a VGA video adapter board (similar to Ubeswitch and others like it) except mine will also have an Atari DIN-13 jack for allowing standard Atari monitors to be attached.
It'll have a couple of multiplexer chips and likely a 5V regulator, so I'm wondering what the limits for the +12V output on the DIN-13 jack of the STe are?
STe | MonSTer with dual IDE-CF memory card adapter | NEC Multisync 1990SXi | ST_ESSC | RSVE | Link '97 | Sony HD floppy drive/AJAX controller | Exxos HD floppy module | Battery-backed Ricoh realtime clock module | Discovery cartridge | C-Lab Unitor-2 | C-Lab Export | C-Lab Combiner | C-Lab Steady Eye | C-Lab Human Touch | Unicorn USB
💧Are you a good person? 💧Living Waters
Re: Max. power output available (STe video out)?
If you look here: ST PSU you can see that for a standard SR98 PSU is rated for 3A @ 5V and 0.9A @12V, so 15W and 10.8W respectively.
12V isn't used for a lot, I believe serial, FDD and possibly the AY sound chip, but you'd have to trawl through the schematics to be 100% sure. Later FDD's and Goteks don't use 12V, which helps. I can't imagine the few components you're going to be using will pull much power.
czietz
Post by czietz »
Pacman was asking specifically for the video port, though. 12 V on the video port has a 1.2 kΩ series resistor. The maximum allowable current can be derived from the minimum required voltage by applying Ohm's law.
czietz wrote: Wed Sep 18, 2024 11:14 am Pacman was asking specifically for the video port, though. 12 V on the video port has a 1.2 kΩ series resistor. The maximum allowable current can be derived from the minimum required voltage by applying Ohm's law.
I was simply providing the information I had about the PSU so he had a starting point and understood the PSU output. He can't use more than the PSU can supply.
In any case with 12v and a 1.2kΩ series resistor it's 0.01 a and 0.12 watts.
Screenshot 2024-09-18 at 14.20.26.png (200.01 KiB) Viewed 739 times
Pacman
Post by Pacman »
I was never any good at electrical theory :?
I'll be using two MUX chips that take around 0.3 mA each at 5V. And I need to convert the 12V line to 5V meaning a voltage regulator of some sort is needed too.
What's the +12V line in the DIN13 connector for anyway? Do the Atari monitors use it for something?
Trying to find an answer to this I just looked up the Info-coach Atari ST interfaces and connectors -Video connector page which doesn't say anything about what it's for but does say "12V/10mA". Does this sound about right?
EDIT: oops! That's just what your calculations showed, Rubber_jonnie: 0.01A :D
... which of course is 10mA
I certainly don't want to cause any potential trouble if for instance an SM-124 or SC-1224 is selected and plugged into my output board. Would it be better to take the power directly from the computer's power supply? I'll most likely get myself a new and better power supply anyway. Depending on how much power each line supplies I might just be able to connect it to the +5V and GND lines directly (instead of using the PSU's +12V line and GND, then needing a voltage regulator to bring it down to +5V).
frank.lukas
Post by frank.lukas »
Pacman wrote: Wed Sep 18, 2024 11:27 pm What's the +12V line in the DIN13 connector for anyway?
https://en.wikipedia.org/wiki/SCART
Automatic Switch Voltage to AV ...
Pacman
Post by Pacman »
frank.lukas wrote: Thu Sep 19, 2024 1:09 pm
I see.
So Atari actually added this 12V line (not present in previous ST models as far as I know, before the STe) with SCART inputs for TV in mind?
I wonder if they issued a DIN13 to SCART cable at some point.
So, when +12V is inserted into the SCART connector's pin 8 the TV automatically selects the SCART input so the user doesn't need to do anything.
Perhaps the best idea for my video output board would be for power (+5V) to be taken directly from the power supply, just to be on the safe side?
I could use multiple power supply 'Y' splitter cables from the power supply to the STe along with the various add-on boards I'm having. Good idea?
Screenshot 2024-09-19 at 17.38.54.png (167.39 KiB) Viewed 644 times
As recently discussed the Exxos ST2VGA adapter (https://www.exxosforum.co.uk/atari/store2/#0170) uses the 12V line to power its circuit, so if you keep your current requirements low enough it's a perfectly feasible power source.
Pacman
Post by Pacman »
Is the Exxos ST2VGA a variation of the Ubeswitch but without the programmable logic?
It's hard to tell from the photos here (and elsewhere) but if it's anything like the Ubeswitch it'll use a TS5V330 multiplexer (which, according to the datasheet draws maximum 3uA (0.003mA). There's also a 78L05F voltage regulator which I'm not sure how much current it draws.
The two MAX4885 multiplexers I plan to use in my board appear to be drawing a lot more (300uA, or 0.3mA) each which is strange when compared to the MUX in the Ubeswitch, but that's what the datasheet says. Then there's the 5V regulator (unless I power it directly from the computer's power supply 5V line as suggested earlier.). In that case, would I need to insert a current limiting resistor between the power supply's +5V and the +5V inputs of the MUX chips?
