ST536 and diagnostic cartridge issue ?
Is anyone able to test either a TF536, ST536, STE536 with the STE diagnostic cart ?
I thought it worked, but on my STE, it seems to lock up just before it gets to the menu.
I6 Checking exception handling...
I7 Bus error not detected
I tried the Falcon diagnostic cartridge as well..
Hello World
Looking for VME RAM
VME RAM not found
Looking for FPU
FPU not found
Checking Bus error handlingI7 Bus error not detected
EB Bus Error  Access Address: FA03EA Program Counter: 1513FC
E9 Bad instruction fetch
I'm not totally sure if the Falcon diagnostic cartridge even work on a STE properly. But maybe someone can also confirm that..
Re: ST536 and diagnostic cartridge issue ?
Looking around it seems to be mentioned before as well viewtopic.php?t=4582
At this point I just assume the diagnostic cartridge is simply not 030 compatible..
coonsgm
Post by coonsgm »
I'm building a Sidecart today or tomorrow and should be able to test later this week.
frank.lukas
Post by frank.lukas »
exxos wrote: Mon Aug 12, 2024 2:46 pm At this point I just assume the diagnostic cartridge is simply not 030 compatible..
Yes and you can not use the Falcon or Atari TT Cart ROMs ...
The sources for the Falcon cartridge are on the net, perhaps you can use this as a basis to write your own new one for all ST computers with 020/030 accelerator cards ...?
frank.lukas wrote: Mon Aug 12, 2024 3:01 pm Yes and you can not use the Falcon or Atari TT Cart ROMs ...
OK thanks.
That would be useful yes, but beyond my abilities unfortunately.
DIAGROM may work, I have permission to use it for a product, but I always think demand is to little for such a item. It is a free download though. viewtopic.php?f=72&t=1201
frank.lukas
In my opinion Diagrom is not a replacement for the Atari Test cartridge ...
frank.lukas wrote: Mon Aug 12, 2024 3:12 pm In my opinion Diagrom is not a replacement for the Atari Cartridge ...
That's all there is though unless someone fixes the Atari stuff.
