FreeMiNT 1.19 + N.AES issues
General Discussion, STOS.
mikro
Post by mikro »
I don't want to pollute the Raven thread...
agranlund wrote: Sat Aug 10, 2024 11:22 pmI use Mint 1.16.0 because I never had much luck with 1.19+NAES.
Just random freezes with that setup. Same thing on my 520ST, the V4SA, and Raven. Extremely frequent with network enabled but also even without.
I'm sure it must be something with my Mint setup but reverting to 1.16 on all machines solved the issues for me so I'm happy using that version.
@agranlund, as I have seen various notes about 1.16 being more stable with N.AES and/or networking, it's possible there is some issue hidden deep inside.
Officially, I'm aware of only one N.AES issue: https://github.com/freemint/freemint/issues/143 which is easily solvable by putting gemcon=false in the configuration file.
So, when/if you find some time (yes, I know, quite an expensive commodity..):
- the random freezes are specific to N.AES only? I.e. if you boot with a recent snapshot into XaAES, do they still occur?
- when you say it's "extremely frequent" with network enabled: do you have to conduct some network i/o or merely a presence of network driver (which one?) makes things worse? And again, can you say the same when booting into XaAES?
Return to “SOFTWARE”
