Exxos's B-roll blog of nothing in particular
So the old van windscreen washer motor died this week. Was working.. until it wasn't. MUCH confusion what fuse it was even supposed to be. In the end, ordered a new pump. Feking annoying place, as it was behind the wheel arch liner! Those push-fit clips are a nightmare to let go! I only broke one - Don't care.
Tested electric was getting to the connector. Thankfully it was. Thankfully new pump turned up on time, about a hour after I started taking stuff to bits.
All working again now :)
Darklord
Re: Exxos's B-roll blog of nothing in particular
Post by Darklord »
I know I've gotten to the point where I almost dread working on a lot
of things (especially on newer vehicles). That's one reason I've held
on to my 2006 Chevy Trailblazer for so long.
Some of the sensors - geez! the places they stick them into makes
me think that they put the sensors in, then built the danged car
around them... :mad:
Darklord wrote: Thu Aug 01, 2024 3:42 am Some of the sensors - geez! the places they stick them into makes
They do.
Not as bad as the mid noughties Renault Clio where the official method for replacing a headlight bulb included dropping the front suspension to get access.
Darklord
Post by Darklord »
stephen_usher wrote: Thu Aug 01, 2024 6:25 am
They do.
Not surprised. I can still recall a friend of mine who owned a Monza Spider telling me that the version that had the V8 in it (it really wasn't a big car), had to have the motor mounts taken loose on one side and jack the motor up to change the spark plug closest to the firewall. :roll:
Dealing with ant infestation this week :(
Ended up putting double sided tape on some paper across the door to try and contain them! Probably catches 90% of them!
Got a A4 card covered in tape in the window to catch the flying ants.
Yesterday it was like a horror movie of bugs pouring out of the walls!
Took the patio bricks up outside next to the wall. Been cermenting up all the cracks to try and stop them finding food etc. They *should* be contained within the wall at this point.
Oh the fun of it all..
I've been having fun "fixing" our toilet which wouldn't flush anymore :roll:
After screwing around with it all day, I decided just to oder a "universal" kit to replace everything inside the tank. I had already bodged a new refill valve and hacked it in to work a few years ago.
First problem is our downstairs toilet is more like a cupboard its that's small. So gymnastics was required to even get behind the toilet. I needed the tank fully. But of course it was bolted down.. Since it's been there since 1986 the bolts were just a blob of rust sadness.
No worries I thought as I bought a new dermel set a few years back. First cutting wheel was blunt but I had spares.. I then spent about half hour trying to undo the wingnut by the power of swear. But later tried heating it up with my gas soldering iron but gave up and went back to cutting.
About a hour past as was getting nowhere fast. The dremel was getting to hold to hold it was burning my hands!! Then the shaft decided to turn into a half molten mess and fell off. No worries as I had others.. Several other shafts later.. Was getting a bit annoyed. They snapped in 2 seconds so I kept having to untangle myself out of the room to change them..
About 3 hours later I managed to get the tank off. Fitting the new bits was some sort of un-comprehensible nonsense. To make matter worse. The new flush mech was a tiny bit longer than the old one. It didn't fit flush to the bottom of the tank. I upped it with using the old a new washer to give it more clearance. Went outside, filled it full of water, thing was leaking out of everywhere and the flush still didn't bloody work!!
The main problem so far was I had to turn off the house mains water to i late the toilet. Stupid it didn't have a tap. I guess the house builders didn't care as it was right next to the master valve anyway. So I HAD to get it fixed because the house was without water.
By this time it was about 5pm. Had some food. Decided to start over. I 3D printed a big spacer and made it 7mm high. I put that under the flush mech with a couple of rubber washer to seal and lift the hole thing up so it would clear the tank sides. I also put a thin layer of silicon sealant on it all for good measure.
Put the tank back on the toilet and filled it slowly with water. No leaks now. The flushing started to now work!
The water level was to high. So started to adjust it and BOOM. The refill valve blew apart in a explosion of water in my face. Now the room is underwater. I am soaked and so are the wall.
I then spent a hour trying to figure out what the hell just happened. I can only assume the defill valve wasn't tightened up "out of the box".. But wait there's more..
Somehow in the explosion a rubber washer vanished. It wasn't anywhere. Trying to figure out how to reassemble the valve was worthy of the krypton factor. No instructions at all. We found a video on YouTube which gave us some clues which showed where the washer should be..
I had a couple of universal washers kits. So tried a lot until I found one which worked. Now it's all back together I've now found there's a low pressure and high pressure nozzels for the refill valve. We only had 2 low pressure nozzles. Which were being used on a high pressure water mains. Which was probably a key factor why the whole thing exploded.
So currently it's all back together. The master tap is turned on only a tiny bit. It can be Mondays problem now. While I can buy other nozzles, I'm going to to print a insert reducer rather than use the high pressure nozzle. Why? Because the high pressure nozzle has a smaller hole which gets forced against a rubber washer. I'd be happier having the larger hole for the contat area and just have a reducer inside the nozzle to reduce the water flow.
So while the thing exploded and flooded the toilet room out. I think I'm getting the hang of it all now.. :lol:
Fixing the toilet turned into a ongoing nightmare but seems to be finally fixed ! Things have to be tightened up to the point where you think they are going to snap in half ! Also had to take it all to bits because the washer between the tank and the toilet seat I had not put on correctly :roll: it doesn't help when the assembly instructions for these kits have technical drawings which are like the size of a postage stamp and do not even explain what it is supposed to go where ! Obviously I guessed wrong first time around :roll:
This weeks problem is that I could not open my wardrobe doors very easily. I found out the whole thing was starting to lean to the right causing the doors to stick on withdrawals at the bottom :roll:
Pushing it to the left slightly and things lined up better..
So I screwed a block of wood onto the wall to keep it straightened up..
It did the job but every time I walked across the floor it would "creak". I tried putting gasoline I to think it would quite it down but did absolutely nothing!! :roll:
Then I ended up screwing another block to the first block, and then screwing the wardrobe from the inside into the block to stop the whole thing moving!
DIY is definitely not in my skill set, but it got the job done !
mrbombermillzy
Post by mrbombermillzy »
I love stuff like this.
It makes me feel not so bad about my own DIY skills! :D
exxos wrote: Fri Aug 22, 2025 2:52 pm I tried putting gasoline I to think it would quite it down but did absolutely nothing!! :roll:
Hmm... lets see...
*Friction
*Combustible material (wood)
*Gasoline
What could go wrong?
:fire:
Maybe limit the no. of times you travel in and out of the room to 3 a day, max. just to be safe.
:lol: :hide:
Was supposed to say Vasoline , still not sure it's spelt correctly :lol: :roll:
Post by JezC »
Vaseline...
But the auto-correction is way funnier!
:D
