STE 32MHz PLUG IN BOOSTER ON/OFF
gigi92
Post by gigi92 »
hello for my new 520STE (after playing with stf) who will be at home this week, i think i will by STE 32MHz PLUG IN BOOSTER REV.
Is it possible to switch booster 32 to 8 and 8 to 32 ? harware ? or with program ?
Thanks in advance.
HigashiJun
Re: STE 32MHz PLUG IN BOOSTER ON/OFF
Post by HigashiJun »
gigi92 wrote: Fri Jul 12, 2024 1:29 pm
Is it possible to switch booster 32 to 8 and 8 to 32 ? harware ? or this program ?
Thanks in advance.
Yes, check the FAQ below:
viewtopic.php?f=24&t=4441
gigi92
Post by gigi92 »
HigashiJun wrote: Fri Jul 12, 2024 1:42 pm Yes, check the FAQ below:
Connect the SW pad on the booster some 0v somewhere to disable the boosters 32Mhz mode and enables 8MHz mode. : some one has illustration ?
Thansk
The key statement is this:
Q) How do I enable 8MHz mode
I have 2x 32Mhz boosted STEs, one with an early solder in booster, the other a plug in booster, just a much earlier version and on both I fitted a simple on/off type switch between the SW pad and ground so I can select 8 or 32 Mhz at the flick of a switch.
I don't believe you can switch on the fly though (I am happy to be corrected on this) so I always select the speed I need before powering on.
It isn't like the MSTE that allows speed selection via a control panel app.
gigi92
Post by gigi92 »
Thanks for your reply, for now i do not have booster, when is at home it will be me easy to show PAD SW.
HigashiJun
IIRC, the SW pad is clearly indicated on the PCB.
Don't forget to get a "FAST TOS" upgrade with your booster.
HigashiJun wrote: Sun Jul 14, 2024 10:30 am IIRC, the SW pad is clearly indicated on the PCB.
100% for the FAST TOS upgrade 👍
gigi92
Post by gigi92 »
:D
PURCHASED ITEM: STE 32MHz BOOSTER V1 PLUG-IN V4sm
REQUESTED QTY: 1
PURCHASED ITEM: ATARI STE 1.62 / 2.06 TOS ROM FRENCH
REQUESTED QTY: 1
PURCHASED ITEM: RESET CIRCUIT CAP FIX
REQUESTED QTY: 1
PURCHASED ITEM: 9 PIN SIL RESISTOR 1.2K
REQUESTED QTY: 1
PURCHASED ITEM: 9 PIN SIL RESISTOR 2.2K - PACK 5
REQUESTED QTY: 1
PURCHASED ITEM: 9 PIN SIL RESISTOR 10K
REQUESTED QTY: 1
PURCHASED ITEM: 74F257
REQUESTED QTY: 1
PURCHASED ITEM: STE DUAL TOS 1.62/2.06 PCB
REQUESTED QTY: 1
PURCHASED ITEM: ROUND PIN CONNECTOR STRIP
REQUESTED QTY: 4
PURCHASED ITEM: PLCC44 SOCKET
REQUESTED QTY: 1
:girldance:
HigashiJun
:cheers:
