HDDRIVER card sizes
chronicthehedgehog
HDDRIVER card sizes
Post by chronicthehedgehog »
I'm trying to switchover to HDDRIVER from ICD Pro at the mo
I'm using 32GB cards but it seems that maximum it's prepared to partition is 1GB. According to the docs it looks like it should be 2GB. Has anyone successfully used large cards with HDDRIVER or should I buy some smaller SD cards?
ICD Pro happily accepts large cards and allows you to create 14 * 512Mb partitions. As I was expecting HDDRIVER to be similar, I've spent the evening confusing myself and looking for partitioning options that probably aren't there IYSWIM. So I've come to accept that I need to use smaller cards I think.
Apologies if I sound like I'm griping. It's just been one of those unwelcomed time sinks :lol:
Re: HDDRIVER card sizes
chronicthehedgehog wrote: Fri Jun 21, 2024 11:30 pm I'm trying to switchover to HDDRIVER from ICD Pro at the mo
The HDDRIVER websites says: "On the part of HDDRIVER there is no upper limit for the capacity of mass storage media. "
If you're using it with an ST and TOS then you will hit the maximum partition size, which IIRC is 512MB. I think the largest drive I've used is 16GB and I was able to split that into multiple 512MB partitions like you've done with ICD Pro.
Have a look here: HDDRIVER Overview.
chronicthehedgehog
rubber_jonnie wrote: Sat Jun 22, 2024 12:09 am The HDDRIVER websites says: "On the part of HDDRIVER there is no upper limit for the capacity of mass storage media. "
Ah OK. I think I only skimmed that so missed it. Wasn't mentioned in the manual IIRC. Anyway, guess I'll keep trying :D
Thanks
chronicthehedgehog wrote: Sat Jun 22, 2024 12:13 am
Thanks
You should be able to partition as you've described with ICD Pro, I have done so lots of times, however since TOS is limited to 512Mb partitions I don't usually go much beyond 8GB since you end up with unused space which is a bit of a waste.
It is getting harder to get smaller sizes these days though that's for sure.
chronicthehedgehog
Success :D
14 shiny 512Mb partitions
Linux to the rescue. Used fdisk to create a 32GB FAT16 partition. I probably did the same last time but it was a while ago
HigashiJun
Post by HigashiJun »
Add BIGDOS to the AUTO folder of your HDDRIVER and you will be able to get more partitions...
chronicthehedgehog
HigashiJun wrote: Sat Jun 22, 2024 1:03 am Add BIGDOS to the AUTO folder of your HDDRIVER and you will be able to get more partitions...
it has crossed my mind :D
HigashiJun
:dualthumbup:
Return to “NOOB QUESTIONS”
