STacy external monitor port?
Darklord
Post by Darklord »
Okay, as I've mentioned multiple times, I'm horrible with schematics, except for the blindingly obvious.
So, if possible, I really need some information on the STacy's (inside view) external monitor port.
Can someone look at the schematics and please tell me what 1, 2, 3, and 4 are? I'm pretty sure that
there's a horizontal sync, vertical sync and maybe audio? I'm not sure what the last one would be and
I'm not sure about which is which.
Thanks all, appreciated. :)
Atari STacy External Monitor Port (inside view)2.jpg (227.8 KiB) Viewed 1076 times
sporniket
Re: STacy external monitor port?
Post by sporniket »
hello,
Here is a map of the pins soldered on the motherboard, seen from above your motherboard :
Capture d’écran du 2024-06-06 20-55-02.png (60.63 KiB) Viewed 1065 times
Hope this help.
EDIT : this is taken from my 260/520ST conversion under Kicad, and it's the same for the STe, and I assume also on the STacy.
Darklord
Post by Darklord »
Thanks for that. I guess I'll just have to figure out how that translates
to the 4 numbers in the picture I posted above.
Darklord wrote: Thu Jun 06, 2024 9:31 pm Thanks for that. I guess I'll just have to figure out how that translates
Those would be:
  • Audio out
  • Composite video
  • GPO
  • Mono Monitor detect.
Darklord
Post by Darklord »
stephen_usher wrote: Thu Jun 06, 2024 9:47 pm
Those would be:
  • Audio out
  • Composite video
  • GPO
Thanks, appreciated.
I'm still confused though. How is this STacy owner on Facebook getting Hsync and Vsync from Pin 1 and Pin 4
for his RGB2HDMI installation in this picture?
Darklord
Post by Darklord »
Maybe I'm just looking at this all wrong. Here is the section from the RGB2HDMI github,
showing what's needed for the ST. I need to figure out where to hook up Hsync, Vsync
and Blank from the 12 bit buffer board to the STacy somewhere...
Atari ST Shifter.JPG (97.54 KiB) Viewed 1045 times
LarryL
Post by LarryL »
Darklord wrote: Thu Jun 06, 2024 9:55 pm
Those would be:
  • Audio out
  • Composite video
  • GPO
Hard to say without knowing exactly what the other guy on Facebook did…
Definitely not getting Hsync and Vsync from pins 1 and 4
They are on 9 and 12
Just an idea:
If he wants to insert Audio into HDMI (behind RGB2HDMI) he needs the Audio signal (Pin 1)
If he wants to switch between Mono and Colour from outside the computer he needs access to the Mono detect signal at Pin 4 (pulling this to GND switches to Mono)
So I assume (if it is really 1 and 4) these two signals are not used for the RGB2HDMI itself, but for additional purposes
If this is 9 and 12, all is good :D
Darklord wrote: Thu Jun 06, 2024 10:08 pm Maybe I'm just looking at this all wrong. Here is the section from the RGB2HDMI github,
Exactly, these are the signals you need to input into RGB2HDMI
I do not have the STacy schematics at hand, but Hsync/Vsync/Blank should be somewhere… :D
Edit: checked the schematics… close to the shifter there should be three diodes (D7, D8, D9) - where they connect is Blank
Cheers
Michael
Darklord
Post by Darklord »
My problem is that I suck vacuum hard at reading schematics, unless they are
overwhelmingly obvious. That's just truth.
I've got another picture from another STacy owner who installed the RGB2HDMI
mod, and it makes more sense but it's not exactly clear either. Unfortunately,
when I inquired further, he said that he had already closed everything up and
wasn't sure about the connections.
If I zoom in on that picture, I can almost see what's happening. I'll attach it. I
labeled it and I think I've followed the 3 wires correctly.
STacy-RGB2HDMI (zoomed in).JPG (279.52 KiB) Viewed 1014 times
He’s obviously designed a board which fits into the Shifter socket and extracts the signals from there and the Shifter then plugs into his board on top.
Darklord
Post by Darklord »
stephen_usher wrote: Fri Jun 07, 2024 7:06 am He’s obviously designed a board which fits into the Shifter socket and extracts the signals from there and the Shifter then plugs into his board on top.
Oh, that's a kit you can buy complete now. You don't have to do all the lines in the previous versions.
It's down to just 3 wires, Blank, Hsync, and Vsync. Once you figure out where they go, of course. :lol:
https://www.sellmyretro.com/offer/detai ... ~ste-61574
