https://www.amigaworld.de/hardware/amig ... d-adapter/
Tf1260 oboard HD IDE LED
I found this adapter that can be used with the TF1260 but will this allow to use both the MB and TF1260 onboard IDE to work at the same time
Where does it connect on the TF1260
addicted to Amiga hardware for far too long
- Admin sponsor
Re: Tf1260 oboard HD IDE LED
There is no HDD LED header on the TF1260. You would need to solder something or get a CF card with a HDD LED header on it.f1lupo wrote: Mon Apr 08, 2024 11:54 pm I found this adapter that can be used with the TF1260 but will this allow to use both the MB and TF1260 onboard IDE to work at the same timeWhere does it connect on the TF1260
thanks I guess it's useless for my TF1260 in that case...I use a DOM and there's no LED header on it
update:
saw a thread on AmiBay where someone got this adapter to work with TF1260 onboard IDE by soldering to Pin 39 on 1200 IDE
update:
- Admin sponsor
Yes you would need to find an appropriate place to solder. But i've no intention of helping people do this as its all liability for me with no gainf1lupo wrote: Tue Apr 09, 2024 9:44 pm thanks I guess it's useless for my TF1260 in that case...I use a DOM and there's no LED header on it
update:
