Issue adding items to the cart
Paul_M_71
Post by Paul_M_71 »
Hi
I am in the process of purchasing the Falcon monitor adapter but I also wish to add the 50MHz OSC. When I click the BUY button, for some reason the 40MHz version then shows '1 items in your basket' and the CART then shows both the 50MHz and 40MHz derivatives, but only adds the price of the 40MHz to the total cost. I have tried to order on a different web browser, but encounter the same issue.
It would be appreciated if others would check if they meet the same issues and offer a suggestion to rectify the problem as I do not want to inadvertently order incorrectly or to not pay for the shipped items.
Thanks
Paul :)
Re: Issue adding items to the cart
@Paul_M_71 Thanks for bringing it to my attention.
The stock codes for both 40MHz and 50MHz were the same it seems.. my bad sorry. I'm not sure what would happen if trying to order 2 codes of the same number. Id assume you would have got billed for both parts. The total shown in store is just a "display value" (would be to easy to hack otherwise) . So all the actual payment calculations are done totally in the backend of the Stripes payment system. I shall shut up now, else one of the Admins will start redacting my comments again :lol: :roll:
Anyway, The problem should be fixed now :). I have given the 50MHz a new stock code. So should fix your problem.
Paul_M_71
Post by Paul_M_71 »
That's great, thanks for fixing it.
Order now placed :D
