VR177x (WD1772 replacement)
Locked
It looks like vRetro in New Zealand have come up with a replacement for the WD1772. I don't think it has been released yet and isn't in the store, but I wonder if it is running at faster clock speeds like the Ajax.
Gooeyblob
Re: VR177x (WD1772 replacement)
Post by Gooeyblob »
Yes - " is designed to operate at both 8MHZ and 16MHZ the signal at the clock input pin is measured and the operating frequency set internally to match. If there is no clock signal present then if the clock input is 0V then the frequency internally is set to 8MHZ, if the clock input is +5V then the frequency is set to 16MHZ. This means a very simple interface (no external oscillators needed) can be used to change from DD to HD. In fact every gotek can be programmed to set HD/DD status on pin 2."
Gooeyblob wrote: Thu Jan 18, 2024 11:33 am Yes - " is designed to operate at both 8MHZ and 16MHZ the signal at the clock input pin is measured and the operating frequency set internally to match. If there is no clock signal present then if the clock input is 0V then the frequency internally is set to 8MHZ, if the clock input is +5V then the frequency is set to 16MHZ. This means a very simple interface (no external oscillators needed) can be used to change from DD to HD. In fact every gotek can be programmed to set HD/DD status on pin 2."
Sounds fantastic, thanks for the info :)
This is the only reference I could find online :
https://atarionline.pl/forum/comments.p ... e=1#Item_0
This is their homepage. Looks like they make IC replacements for various classic computers, concentrating on Sinclair Spectrum
https://www.vretrodesign.com/
The developer is called Charlie Ingley
HigashiJun
Post by HigashiJun »
Very interesting.
chronicthehedgehog
Post by chronicthehedgehog »
alexh wrote: Thu Jan 18, 2024 12:08 pm https://www.vretrodesign.com/
I bought a ZX ULA replacement from him in the past. Quality stuff.
Yeah, it's Charlie Ingley.
troed
Post by troed »
Surprising that Gotek has pin 2 as an output. In the spec (and in the world of real floppy drives) it's an input.
However, it should work fine modifying the drives we know how to do it on - so this would support real drives too,
https://blog.troed.se/2017/01/20/the-ta ... i-mystery/
HigashiJun
troed wrote: Thu Jan 18, 2024 1:06 pm However, it should work fine modifying the drives we know how to do it on - so this would support real drives too,
That would be great.
arf
Post by arf »
Gooeyblob wrote: Thu Jan 18, 2024 11:33 am is designed to operate at both 8MHZ and 16MHZ […]"
Do you know by chance whether a 32 MHz operation (for ED floppies) is planned? That’d be my usage scenario.
Against signature spam!
Locked
