Libretto 100CT - Will it live again!!
In line with my usual random hopping around projects, I pulled the Libretto 100CT off the shelf to see if I could make any sort of headway in getting it running again.
It's not a machine that's new to me, but stopped working some time ago and I just didn't have the tools/skills at the time to fix it, so I didn't try, but held onto it anyway.
I pulled it apart for a good inspection and clean of the major plug connectors:
And to make some repairs to the case, which is pretty fragile.
Overall it seems positive, as I powered it on and I'm getting the HDD spinning up and a CMOS error on the screen, so I at least know there is some sort of life. I have an old CMOS battery, and I should be able to replace it and re-use the cable, hopefully then I can reassemble and get the BIOS set and get booting again, fingers crossed for a successful afternoon.
Re: Libretto 100CT - Will it live again!!
Well, that went a bit quicker than I thought it would!!! First off I found a small enough battery and made a new BIOS battery from the old leads:
It's just a simple non rechargeable battery, so nothing terribly complex. It all booted just fine to its original drive:
At that point I plugged in the PCMCIA FDD drive to see if it was all good, and it worked just fine:
Which was a good sign that it was working as advertised.
I then remembered that I had a 32MB expander, and I'd put it in my spares drawer after the last time I pulled it apart, but didn't refit it, so a quick look in the drawer and there it was:
I cleaned the computer and RAM board connectors, and there it was in both the BIOS and in Windows, which was a relief :)
I've also glued the missing bit of plastic at the hinge point back on, and whilst not perfect, it certainly improves the aesthetics.
I do have concerns about the HDD, it's clunking rather more than I think it should be, so I need to see if I can clone that off onto another drive at some point.
I also need to see if I can dig up the drivers for the dock I have with it, as that adds USB amongst other things, so it'd be useful to have it working.
Overall, very happy with my first fix of 2024 :)
:dualthumbup:
HigashiJun
Post by HigashiJun »
:bravo:
@stephen_usher @HigashiJun
Thanks both :)
