My SD-box refuses to work with TF536 on my A2000.
I'm using the same floppy boot media for both the TF536 and 68000 processor installed, sdbox works fine with the 68000 but not with the TF.
I'm not sure if it's speed/timing related thing or what else could cause the parallel port to behave differently. Is anyone else using the combination ok ?
TF536 and SDBox
- Admin sponsor
Re: TF536 and SDBox
Could be timing or it could be the software doesnt play nice with 030.ADRRichard wrote: Thu Dec 14, 2023 10:00 pm My SD-box refuses to work with TF536 on my A2000.
Are you on the latest firmware?
https://github.com/terriblefire/terribl ... ster/tf536
ADRRichard
Re: TF536 and SDBox
As far as I'm aware I am using the latest firmware, Product 4, Manuf 5080 serial 536. (I can change it easy enough)terriblefire wrote: Fri Dec 15, 2023 8:37 amCould be timing or it could be the software doesnt play nice with 030.ADRRichard wrote: Thu Dec 14, 2023 10:00 pm My SD-box refuses to work with TF536 on my A2000.
SD box works fine on my A1200 with TF1260. I'll keep experimenting and report back any findings.
