I’m having some strange errors with my CT60e. Silkcut can launch under Mint, but not under TOS4.04. So I’m suspecting some kind of memory error.
So… Is there some memtester for the extended memory?
CT60e - memtester?
- frank.lukas
Re: CT60e - memtester?
So, that's a negative.. Are Falcons usually in need of a recap. I guess I can do one since I still got the motherboard out of it's case.
master of the bare pcb
In what way was it a negative?ube wrote: Sat Dec 09, 2023 2:10 pm So, that's a negative.. Are Falcons usually in need of a recap. I guess I can do one since I still got the motherboard out of it's case.
In a good way, no errors from YAARTTT after running for ~16 hours. So the memory seems ok.
But still, I can't grasp why Silkcut runs in Mint and not TOS..
Does the clock patch on main falcon board have any effect on the CT60e when running in 060 with extended memory?
Below is the exception thrown when trying to start Silkcut in TOS.
@mikro, any ideas if it’s CT60e or the machine itself that needs some love?
Silkcut: A TBL Amigademo for Breakpoint 2004
Final version released at 2004-11-28
ニニニニニニニニニニニニニニニニニニ
Atari version (1.02) released at 2008-09-09
by MiKRO / Mystic Bytes
EXCEPTION PROCESSING 11: Line F
Status Register (SR): $2304, bits to 1: 5 I1 IB Z
Progran Counter (PC): 501175170
Basepage: 50115BA7C
Cache Register (CACR): 590808000
Supervisor Stack (SSP): $01159A0
User Stack (USP): 5011E59D6
DĐ: 5011D2134 A0:$011CA39C
D1:500000000
A1:$00000001
D2:5010F21D5
AZ: $011655F8
D3:500000000
A3: $010F21D8
D4:$00000000
D5:$00000000
A4: $011D5A2C A5: 50118CBBC
D6: 500000001
A6: $011E59C8
D7: 50118BEE8
- frank.lukas
Line-F Exception vector
Exception vector 11: An attempt was made to execute an instruction that contained the value '$F' in the top four bits. It is used up to TOS 1.04 by GEM, and is intended actually for the programmming of a floating point unit (FPU).
OF EFFING COURSE!
I had switched FPU off in CT60 settings.
Silkcut now starts in TOS as well.
