Issue with Assembler includes (HATARI Linux)
mrbombermillzy
Post by mrbombermillzy »
I dont have a Windows machine to test this out on currently, but having crossed over to Linux for my Atari development, Ive come across a strange problem. Not sure if its me missing something obvious or not.
Anyway, the issue: Im attempting to compile a file with Devpac v3.10 which Ive split into other files (for ease of readability).
I INCUDE these files at the exact place that I want the code.
Neither (of the 2 included) files have a DATA or BSS section, so shouldnt need any TEXT section reafirmations after the include directive (although I put them in just in case, to no avail.)
This should be straightforward, but when I segregated the included routines out of the main build, they were not actually included: The program compiled and ran, but did not do the tasks in the included file. I even changed the directory to search to the same as the main file one and also set assembly environment up for INCLUDE directory to match in Devpacs editor.
I then even added a Devpac syntatic error in the 2nd include, for the compile pass to trip on, but it didnt even see it.
The only thing that comes to mind as a long shot possibility is the Atari<>*nix pathname reverse slash being a problem on file access on a HATARI drive?
:shrug:
Has anyone else had this problem?
Im using HATARI v2.4.1.
Re: Issue with Assembler includes (HATARI Linux)
I've had gayness as to where in the code the included files are placed :shrug: I remember it drove me nuts for ages. Think HISOFT was picky as well.
I remember I had to move a lot of routines to the start of the main source code because of bizzare include related issues. But can't remember much about it now :(
TheNameOfTheGame
Post by TheNameOfTheGame »
Well, can't comment on the devpac issue there, but if you are using linux for dev, then vasm will do native assembly with devpac compatibility with the -devpac switch.
vasm -Ftos -devpac -o TEST.TOS TEST.S
mrbombermillzy
@exxos Thanks for the gayness confirm. :lol:
You have saved me also going nuts.
I was thinking it could have been Linux, as Ive not had issue with it before now (recently crossed over from M$).
I will try to shuffle the code around then and see what happens.
TheNameOfTheGame wrote: Wed Oct 04, 2023 7:59 pm Well, can't comment on the devpac issue there, but if you are using linux for dev, then vasm will do native assembly with devpac compatibility with the -devpac switch.
Thanks for the tip, but (as usual for me) Im going to be moving over to the 'real thing' in a few weeks (after the OS specific stuff is done), as the HW Im experimenting with is not emulated anyway.
mrbombermillzy wrote: Wed Oct 04, 2023 8:06 pm I will try to shuffle the code around then and see what happens.
Also had odd path related problems. Might have mentioned that before with forward & back slashes doing different things and there's the path in the code for the includes, then paths in devpac for includes. :crazy:
mrbombermillzy
exxos wrote: Wed Oct 04, 2023 8:12 pm Also had odd path related problems. Might have mentioned that before with forward & back slashes doing different things and there's the path in the code for the includes, then paths in devpac for includes. :crazy:
Hmm. I will have to see what happens when I move over to the swanky new H5+TF536 dev machine next week.
I cant wait! :girldance:
EDIT: @exxos if it unscrambles your brain a bit, any commands in the code (like you mentioned INCLUDES above or processor type, etc) override anything set in the Devpac configuration pages.
sporniket
Post by sporniket »
Another thing to take into account, maybe : do you use harddrive gemdos emulation (i.e. a native folder is mapped to a hardrive for TOS) or do you use an acsi hard-drive image ? I've heard that gemdos emulation can have some strange behaviour sometimes.
mrbombermillzy
@sporniket Yes. Ive always used GEMDOS drive emulation, but I have used includes several times over the years with no problems.
The switch to Linux appeared like the trigger (the differing use of the forward/back slash with filenames being a problem internally to HATARI looking like a potential culprit, I would have guessed), but perhaps that is not the case then.
I will see if exactly the same problematic file setup causes the same problems on real HW and investigate further from there.
