Hi does anyone know what this prompt means, trying to load space harrier, it starts loading and then stops with this message prompt
Using a 1MB ACE X68000 with a Gotek attached using an .hfe disk image
Sharp X68000 Screen Prompt
Re: Sharp X68000 Screen Prompt
'Papago' is a really useful App (not sure if on Apple Store) it seems to have a better conversion for Japanese than say Google Translate.
Pretty sure I ran Space Harrier on 1mb as someone at a retro show commented about not having a chequered floor and that was when I had no memory upgrade.
Alot of issues are due to SRAM not being set/saved.
Load MasterDisk V2 and type switch.x if you have not done this already.
Memory should be set to 1mb, you need to press Escape then Save.
Thanks again for the assistance, not yet used switch utility so will try that I forgot there is no bios like a normal pc its in sram settings, I have no backup battery yet got to solder in my nimh replacement, luckily I removed the original nicad just in time before it caused any damage
Dlfrsilver
This message indicates a program error with SR = $2700:PC = $00FF1B0ARetroTec wrote: Sat Sep 30, 2023 11:47 pm Hi does anyone know what this prompt means, trying to load space harrier, it starts loading and then stops with this message prompt
sharp.JPGUsing a 1MB ACE X68000 with a Gotek attached using an .hfe disk image
Retry / Ignore / cancel
- HigashiJun
Dlfrsilver wrote: Thu Oct 05, 2023 8:51 pmThis message indicates a program error with SR = $2700:PC = $00FF1B0ARetroTec wrote: Sat Sep 30, 2023 11:47 pm Hi does anyone know what this prompt means, trying to load space harrier, it starts loading and then stops with this message prompt
Precisely, it should read:
An address error has occurred (SR=$2700:PC=$00FF1B0A)
Cancel <A> Retry < > Ignore < > ?
