Can you use an Atari 1025 printer with an Atari ST
Captain Crunch
Post by Captain Crunch »
I bought a dot matrix Atari 1025 printer the other day , it was new in box, and when I got home realized that it was 8 bit with SIO input output, but the Atari ST only has a RS232 printer input. I really like the little printer and would love to be able to use it with my Atari 520 STFM. Is there ANY way to get them to work together? I am new to the vintage computer hobby so any help would be greatly appreciated!
Re: Can you use an Atari 1025 printer with an Atari ST
I'm not even sure there has been any serial printers for the ST. I'm no printer expert but I only have seen and used parallel port / centronics printers. Problem as well you would need a driver for it. Assuming the printer is standard RS232 interface it could be adapted for the ST RS232 port. But again your likely going to have to write a driver for it. Which would be hard work if you don't know the commands it uses.
If it's SIO then that isn't compatible.
The SIO port on the 400/800 is a forerunner of USB, designed by an engineer who later worked upon the USB standard.
Remember that the Jack Tramiel Atari is not the same one that made the 400/800 or that printer and the engineers who designed the ST mostly came over from Commodore with Jack.
Captain Crunch
So after reading your post I looked into it some more. The printer port is a DB25M. I was told RS232 so I just kept repeating that, never trust facebook groups lol. So I guess what I am attempting to do is go from Atari SIO to DB25M. Is that possible?
coonsgm
Post by coonsgm »
Might be easier to get an Atari 8-bit machine to work the printer :)
sporniket
Post by sporniket »
I would say that you should study how the SIO achieve data transfert (flow control signals, data encoding, ...) and some electrical considerations (voltages of said signal, e.g. RS-232 use ±12V signals to transmit data).
Most likely, you may have to design an adapter SIO <-> Standard interface that involve a little micro-controller of your choice (atmega, esp32, pico,...).
And maybe, someone already did this kind of work (google check -> found something : https://www.atarimax.com/sio2pc/documen ... index.html )
If you’re making a microcontroller interface you may as well make one which talks to the parallel port on the ST.
Cyprian
Post by Cyprian »
stephen_usher wrote: Sun Sep 17, 2023 10:59 pm If it's SIO then that isn't compatible.
SIO is just regular serial port as RS232 and it is quite easy to pair them together, you have to use voltage converter: TTL (0/+5V) vs RS-232 -12V/+12V
http://260ste.atari.org
I know people have hooked up to SIO via USB serial adapters, so I guess in theory that a serial to serial connection might be possible with the right hardware.
But, the ST uses parallel/centronics for printers and not serial, so even if you could build a suitable serial interface, you'd also need to create suitable drivers for it and that's a whole other story.
Better to get an 8 bit Atari to connect the printer to :)
Return to “NOOB QUESTIONS”
