Detecting Fake BluePills - BEWARE
@BrettRogersUK recently sent me his home built ACSI2STM device for testing, since it wasn't working on either his, or his Dad's STEs.
Looking at the docs, the ACSI2STM should show it's firmware version at boot if there is no SD card installed.
This one didn't, so I tested it with a program called Blinky (Attached, just change it from .TXT to .HEX). It's simple and blinks the LED, but it only works on genuine BluePills. (Source: Detecting Fake BluePills)
It works on my 2 BluePills (A relief, I thought they might be fakes), but not on Bretts.
In addition, despite being marked the same as mine, as an STM32F103C8T6:
ST-Link saw it like this:
But mine shows like this:
Which I believe may be the lesser STM32F103C6T6, or even a re-marked bad chip. That said, mine could also still be fakes, just better ones that pass the visual and Blinky tests.
So, I'm posting this just as a warning. Take care to be sure you're getting what you pay for.
Blinky_Test-v0.21.txt
(12.23 KiB) Downloaded 97 times
Re: Detecting Fake BluePills - BEWARE
Thanks @rubber_jonnie I'll test mine later on
PhilC wrote: Mon Aug 07, 2023 4:35 pm Thanks @rubber_jonnie I'll test mine later on
I'm not saying it's 100%, but along with the visual checks, it's definitely worth doing. Be interesting to see your device ID too.
czietz
Post by czietz »
Though, if yours is marked STM32F103C8 but claims to have 256 kiBytes of flash, that's questionable, too:
BrettRogersUK
Post by BrettRogersUK »
Hi Jonathan,
I got THREE of those Blue Pill boards. Two of them identify as 0x410 chips (as you have one of them) and my other one here identifies with a code of 0x414 and passes the blinky test.
Chip markings on the blue pill
chip markings
chip markings
Device detection in the stm32CubeProgrammer - 256kb memory
STM32CubeProgrammer
STM32CubeProgrammer
Screenshot from 2023-08-07 17-05-23.png (19.09 KiB) Viewed 1934 times
Passes blinky test as have got a flashing LED on PC13 however, it flashed without having the BOOT0 jumper set to programming mode.
Thanks for testing it though for me, I have got a known working ACSI2STM device by a guy called Masteries over on the atari-forum. It came from Spain today and I plugged it in and it worked strait away. no messing about. So, at least I know there isn't a problem with the ACSI side on my STE. It can turn into a rather expensive game of operation if not careful with these vintage machines. The blue pill on the Masteries version is marked as a C6T6A.
I know there are others that have built the device based on the github (https://github.com/retro16/acsi2stm) and they have worked straight away without fault so it would appear that I have been extremely unlucky with my blue pill boards. I Have just noticed however that this one may also be a fake as they have printed on the silk screen next to the reset button 'RESRT' instead of reset :lol: :lol: :lol:
Thanks again,
Brett
elterwater
Post by elterwater »
Out of curiosity, is there a known trusted source of genuine blue pill boards here in the UK? I've fallen down the rabbit hole of Farnell and Mouser and can't find anything resembling the boards, just the chips themselves. Any pointers would be gratefully received please :)
It depend upon whether you want the STM or "compatible" ones. AZ-Delivery do one of those. I don't know if it's close enough though.
BrettRogersUK
stephen_usher wrote: Mon Aug 07, 2023 5:59 pm It depend upon whether you want the STM or "compatible" ones. AZ-Delivery do one of those. I don't know if it's close enough though.
One of the boards I used for this was an AZ-Delivery one from Amazon. it was purchased in Jun 2022 with the intention of building the project straight away but life got in the way and I only got round to having a look at the project a few weeks ago.
czietz wrote: Mon Aug 07, 2023 5:11 pm Though, if yours is marked STM32F103C8 but claims to have 256 kiBytes of flash, that's questionable, too:
You're quite right, which is why I am not 100% convinced that mine are real, despite the blinky test passing.
Do you have a link to the data you posted, it would be really useful to have, thanks.
Higgy
Post by Higgy »
elterwater wrote: Mon Aug 07, 2023 5:29 pm Out of curiosity, is there a known trusted source of genuine blue pill boards here in the UK? I've fallen down the rabbit hole of Farnell and Mouser and can't find anything resembling the boards, just the chips themselves. Any pointers would be gratefully received please :)
This is a UK based company. I've used them before, but not sure if I actually bought this device from them, i definitely bought the programmer from them:
https://hobbycomponents.com/st-micro-el ... ment-board
They even answer questions on their forum to assist.
