A new Atari was born today.
I had a bit of a problem with programming of usable ROM, I forgot to byte-swap the ROM files so was stuck with a white screen for an hour or two. It is wonderful what an hour of badminton with a kid outside does to one's brain.
After the game, I checked ROM files, slapped my forehead and byte-swapped the file. 2 minutes later, Atari booted TOS 1.04 with success. After that, I reprogrammed EPROM with Emutos 1.2.1 and TOS 1.04, both are booting fine.
Regarding DAC STV8438, is it normal for that chip to run really hot, ~50C?
And a couple of obligatory first-boot pictures
Flegmatik's build
Re: Flegmatik's build
Nice job!! And yes to the DAC getting hot
Today I've fitted 16MHz BOOSTER 2021 edition, burned 256K Emutos on EPROM, implemented a partial audio fix, plugged in the Blitter chip, added S2 Midi board and played some games.
I tested MIDI sound with Bomberjack and it works as expected.
Partial audio fix
Booster, S2 and floppy cable
Crammed all together into 1040STF case
Gembench without Blitter (VDI is slower on Emutos than 2.06)
Gembench with Blitter
Every self-respecting system needs a shell
And the game of Joust
Partial audio fix
3.3V bus fix today. I hope I'll be able to test it out one day
All clean up
220K resistors in place
All clean up
Hurrah! Godo job.
