Hello,
A Guy posted about his TT030, and he gets this on screen :
For me, it's either a TTL fault or a RAM fault.
Anyone has a clue on what the problem can be ?
PS : the screen in itself is not faulty, it works with another ST.
Thanks for any input.
TT030 issues
Re: TT030 issues
Probably a RAM fault.
The shifter is picking up the wrong screen mode so the display is in TT-High but the data in TT-Low mode. It's also crashing with a lot of bombs.
P.S. You should have attached the photo rather than linking to it as those are board rules.
Dlfrsilver
Re: TT030 issues
Sorry, i tried to insert the link with the help of the picture option, but it did not worked.stephen_usher wrote: Sat Jul 01, 2023 6:08 pm Probably a RAM fault.
Thanks a lot for your explanation.
Re: TT030 issues
The trick is to just add the picture as an attachment and then put it inline.
Re: TT030 issues
I have sorted the picture out in the original post. In case you wondered how it got there.
Dlfrsilver
Re: TT030 issues
Thank you !Icky wrote: Sun Jul 02, 2023 12:37 am I have sorted the picture out in the original post. In case you wondered how it got there.
