Atari ST first model power port ?
Hello,
I am looking for data about the 7 pins, male, round power port of the Atari ST first model. It obviously is not a usual "DIN port".
Ideally a standard part datasheet with measurements for the footprint. (I already have measurement, but I would like it to know that it was a standard "pots" -parts on the shelf- of that time, and maybe still sold as NOS.)
Thanks in advance.
Thanks in advance.
Re: Atari ST first model power port ?
I just found that, too : https://www.polyplay.xyz/Power-Socket-f ... -ST-7-pole
When I built my replacement PSU for my 520ST, I just used a female 7 pin plug I got off ebay and trimmed the plastic shroud back, works perfectly.
Thanks for the tip @rubber_jonnie
Another source : https://rudedogretros.co.uk/product/ata ... pcb-mount/
The photo of the back show a brand "Singatron"
If there was an actual date sheet I might be able to track the actual part down and possibly even obtain some
I did buy a stack of chassis mount connectors many years ago with the intention of building a new ST power supply but that idea got abandoned.
Ahh, actually I think I misunderstood. You wanted the part that attaches to the mainboard, not the plug that fits into it, sorry, my mistake.sporniket wrote: Tue Jun 13, 2023 10:13 pm Thanks for the tip @rubber_jonnie
no problem, there was a usefull tip for a connected (pun obviously intendedrubber_jonnie wrote: Tue Jun 13, 2023 10:28 pm Ahh, actually I think I misunderstood. You wanted the part that attaches to the mainboard, not the plug that fits into it, sorry, my mistake.
The fact that it's called "DIN" like the usual DIN ports do not help... Either abusive use of "DIN" (because round and pin numbering and arrangement), or there is a spec number to know (like midi ports follows DIN 41524)exxos wrote: Tue Jun 13, 2023 10:27 pm If there was an actual date sheet I might be able to track the actual part down and possibly even obtain some![]()
This here. I did the same and used a meanwell RT PSU to connect to a female 8 pin plug (I couldn't find a 7 pin one and just connected the lines I needed to).Re: Atari ST first model power port ?
Unread post by rubber_jonnie » Tue Jun 13, 2023 4:53 pm
Works like a charm
