Hi all,
I'm not currently doing modding work because of my commitments & study/apprenticeship, but a previous customer has contacted me who is experiencing SCSI issues.
Is there anyone else who can do some Falcon work? Otherwise, I'll see if I can arrange some time in the Holidays.
Thanks,
Anyone free to fix this Falcon PCB?
- HigashiJun
Re: Anyone free to install a falcon clock patch?
Would be glad to help Steve, but I am not sure your customer would be eager to send his Falcon to Japan...
Thanks Jun
The problem has turned out to be something different now, after further inspection - the internal SCSI header made by C-lab seems to have 'burned out' and the traces have gone up in smoke... the guy will either need some patch-trace work done, or a completely new scsi connector board.
I have a theory now that C-Labs internal SCSI board just isn't well made & the traces just weren't designed to be thick enough. They're very very tiny for the voltage rails. Either that or it was just a defective PCB.
- frank.lukas
.. think there was fire up the TermPower Line ?
Yes... check this. You can see previously I had patched some burned traces on the board, but now a trace at the front has completely gone up in smoke.
Re: Anyone free to fix this Falcon PCB?
There must have been something really wrong with a device on the SCSI bus to do that. Possibly a terminator with a short? There should be minuscule amounts of current involved.
- frank.lukas
The problem is that the internal C-Lab SCSI Adapter picks up everything on the onboard terminators and there is no Fuse !
Have one CLAB adapter that looks normal, doesn't work. Never looked into it.Steve wrote: Fri Mar 10, 2023 3:24 pmYes... check this. You can see previously I had patched some burned traces on the board, but now a trace at the front has completely gone up in smoke.
A guy in Spain sold some nice internal boards some years back, can't remember his name. Replaced the MKX boards with those, work great.
But, wow, that's scary looking
- HigashiJun
Here's the guy's web site:Rustynutt wrote: Fri Mar 10, 2023 11:37 pmHave one CLAB adapter that looks normal, doesn't work. Never looked into it.Steve wrote: Fri Mar 10, 2023 3:24 pm
https://www.arananet.net/pedidos/produc ... -cosmos-ex
Still waiting for one but they are all "Out of stock"...
I guess @stephen_usher is right concerning the short on the terminator.
