TF360 - Shapeshifter won't start
Ok, I'm ran out ideas.
I have TF360, and I want to launch ShapeShifter. But I can't. Everything I see is a grey screen. Nothing is loaded. I'm using MuLib package and MuEVD - but it doesn't work. And in MULTISCAN Productivity mode is quite slow. And second question: why I can't use CD-ROM? When I insert CD into CD drive, it doesn't start to rotate. So I can't make fresh Install of OS 3.9 SE under Amiga, I have to do this under FS-UAE. Which 060.library will be the best for this card?
- Admin sponsor
Re: TF360 - Shapeshifter won't start
Shapeshifter should work. You'll need to use the MuMove4K instead of the shapeshifter bundled tool. This is well documented.OSH wrote: Mon Mar 06, 2023 9:57 pm Ok, I'm ran out ideas.
The CD Drive support is not yet perfect but you're on your own for software support here. I'd assume the TF360 CD support is the issue. Its something i'm working on.
Steve, I'm Using MuMove4K with prepareemul parameter. But it doesn't help... Fusion works and loads MacOS, Shapeshifter doesn't...
- Admin sponsor
I can take a look when i get a minute. cant think why it would work on the 1200 and not the CD32.OSH wrote: Mon Mar 06, 2023 11:05 pm Steve, I'm Using MuMove4K with prepareemul parameter. But it doesn't help... Fusion works and loads MacOS, Shapeshifter doesn't...
1. try first with default driver and turn MMU OFF in Shape Shifter Video configuration
2. CD-ROM - if it works in FUSION (the same MacOS, I assume), it should work with Shape Shifter as well. Are you sure you got a proper device and unit set up?
I don't think Shapeshifter has proper 060 support. I know Fusion does - so just use that and be happy?
If you're using MacOS < 8.1 it works, you have to jump through some hoops to get it to work but it does work.dalek wrote: Tue Mar 07, 2023 10:05 am I don't think Shapeshifter has proper 060 support. I know Fusion does - so just use that and be happy?
1. Didn't help, BUT: two times I saw welcome MacOS screen. First time it's frozen, second time system was loaded completely, but then iI had instant reset.arti040 wrote: Tue Mar 07, 2023 5:21 am 1. try first with default driver and turn MMU OFF in Shape Shifter Video configuration
2. I said about CD-ROM under AmigaOS not MacOS
No, because is significant slower and can't use MuEVD driver.
But which hoops? REMAP8K is disabled, A/ROSE too.
- Admin sponsor
Like i said CD support is WIP right now. it does work but maybe not perfectly all the time.
Steve I understand, but for me more important is, why I can't launch ShapeShifter correctly. I need a confirmation or negation from someone, who own TF360.
