Apple ][ VGA Adapter - has anyone tried these?
I'm considering getting one of these: Apple][ VGA adapter since the composite out on my Apple ][ is so terrible.
In fact not only is it terrible, it doesn't work with my Retrotink either.
So I was wondering if anybody had tried a VGA adapter like this and was it worth it. It doesn't have to be the one I linked to, but it would be nice if it's one that is still available.
Thanks in advance :)
Tomswork
Re: Apple ][ VGA Adapter - has anyone tried these?
Post by Tomswork »
Yes I have that card it works very well I also have there other card the goes on a ramworks card. Ramworks clones such as the Ramworks 3 card and the vga adapter work without extra wires
Tom
Tomswork wrote: Mon Jan 30, 2023 4:41 pm Yes I have that card it works very well I also have there other card the goes on a ramworks card. Ramworks clones such as the Ramworks 3 card and the vga adapter work without extra wires
Tom
Cool, thanks Tom, I will dig a bit deep then :)
Do these adapters manage to get the colours right? Apparently a lot of them are not real colours but vertical monochrome lines which match the NTSC colour frequencies (interference colours).
stephen_usher wrote: Mon Jan 30, 2023 8:52 pm Do these adapters manage to get the colours right? Apparently a lot of them are not real colours but vertical monochrome lines which match the NTSC colour frequencies (interference colours).
I honestly don't know, hence the ask, but the basic fact is that the composite on it is really poor. Colourful for sure, but shimmery and not a patch on the composite of many other comparable machines.
Admittedly, not so bad as to be unusable, well, unless you drop into 80 column mode, but worse than my TRS80 model 1 on the same display. I'll have a look at whats about that @Tomswork linked to, see if I can get any idea of any compromises.
Just had a quick look and there's one small problem. I already have an 8M RAM card, and whilst I'll never likely use that much, I don't want to replace it with a smaller one. Plus the cost of the card & VGA option is getting expensive, at least for a machine I don't use a huge amount.
I'll do some more digging around other VGA only options and keep this one on the back burner, though I would say that the colour output (that @stephen_usher mentioned) does look good on the RAMWorks card.
rubber_jonnie wrote: Tue Jan 31, 2023 9:22 am
This is why many machines had a colour/mono switch added. From what I understand it relied upon that poor output for a lot of the colours. :-)
stephen_usher wrote: Tue Jan 31, 2023 10:35 am
Mine does have a colour/mono switch, however whilst the image is slightly more stable, I don't feel the difference is enough to leave it set to mono. I do actually get some artifacted colours, but they are very pale and limited.
And I agree, the poor quality was how they got the colours in the first place, but it'd be nice to loose a bit of the noise.
Tomswork
Post by Tomswork »
@rubber_jonnie
I just realized I live in Canada and my 2e are ntsc but I use bothe cards once on a ramworks card and one is the vga one
Tom
