Using an original internal ST drive with a Kryoflux or Greazleweasle
Dlfrsilver
Post by Dlfrsilver »
Hello,
I tried to find schematics regarding the ST internal drive, because i would like to make an experiment.
I would like to be able to connect a good working original ST drive i have to my Floppy cable connected to my Kryoflux board, in order to dump games using copylocks, and see if i get a result different from the Sony PC drive i usually use.
Thanks if you can help :)
Re: Using an original internal ST drive with a Kryoflux or Greazleweasle
Dlfrsilver wrote: Thu Jan 19, 2023 4:26 pm Hello,
The ST drive is just a normal PC 720KB drive set to DS0. There are a ton of schematics here, but I don't know if there is a specific FDD one: Schematics and other useful stuff
Dlfrsilver
rubber_jonnie wrote: Thu Jan 19, 2023 4:35 pm
What you mean is that i can basically use an ST drive directly on a regular PC floppy Cable 34 pin ?
Yes, but you'll probably need to set it to DS1 rather than DS0 as ST drives are set.
It's done by a jumper or a soldered link on the floppy drive itself.
Normal PC drives use a cable twist for ID.
Dlfrsilver
Ok, i have a problem : once plugged, i get the green diode of the drive always on. And it doesn't work.
I'm missing something, but what ? :?
I have tried DS1 by jumper at the back of the drive, but it gives the same result as position DS0 (default).
Dlfrsilver wrote: Thu Jan 19, 2023 6:52 pm Ok, i have a problem : once plugged, i get the green diode of the drive always on. And it doesn't work.
If the LED is always on, it's likely you have the cable reversed then.
