Bluetooth 5.0 aptX LL HD Audio sender receiver 1Mii B03Pro review
Show us your vintage gear. Be it audio hardware repair, handheld / board electronic games, to synth restoration. Start your own blog etc
mrbombermillzy
Post by mrbombermillzy »
Ever had a faultless BT audio sender/receiver?
No?
Well, neither had I. There's always something wrong; pairing, range (even short and within manufacturers spec), noise, lag, dropout... take your pick.
However, I've had this unit about nine months now and I must admit, it has been absolutely flawless as a receiver attached to a 1970-80s HIFI system.
You can go with the option of slight lag for a higher fidelity (this is the aptX LL) or slightly lower quality for perfect sync, for use in Tv audio.
Unfortunately, I don't count myself as a true audiophile (having Tinnitus is probably not a good start in that respect), but after setting up my altered HIFI system (and curing the out of phase, non colour coded pre-wired speaker cables) the sound is pretty indistinguishable from my Vinyl, if not my CD player (a Technics SL-P220) which actually sounds very impressive through my Technics amp and Phillips made drivers (branded Ekco speakers, who they later took over).
I have yet to pit the output directly against the CD player, but that's maybe a review for another time.
Anyway, here is a link for the unit on the manufacturers web site: https://www.1mii.com/product-item/b03pr ... h-adapter/
Why am I writing this review? I mean, I'm not really known for writing reviews here, but when something has done an unexpectedly faultless job and has some other great features at a very reasonable cost, then I think it deserves a little pat on the back.
I wholeheartedly recommend this great little device. :dualthumbup: mBmZy score: 9/10 *
* Would have got a 10/10, but sometimes, if you are running an audio playlist and if there's not enough of a 'stop/start' gap between tracks, it misses the playback enable and the track plays silently, until the next track is auto started in the playlist, essentially 'bump starting' the audio again. Not sure if this a problem with the player SW (tested Media Player Classic along with MPC-BE x64 on W10) or the actual BT chip being a bit slow with the play/stop commands. Easily solved with stopping and pressing play again in good time, but still marring an otherwise perfect product. If I find a solution to this hiccup, I will update here.
Return to “VINTAGE GEAR ZONE”
