For some reason I had it in my head that the 354 was a 360k drive and the 314 was 720k but I just read in the 314 service manual that is a 360k unit. Are both drives both sizes?
Thanks
Utr
Floppy drives
Re: Floppy drives
The SF354 is a single sided drive with only one head and only supports 360K SSDD media. IIRC it will read just one side of 720k floppies, but of course the disks cannot be flipped so the other side remains inaccsessible.UnderTheRain wrote: Tue Dec 20, 2022 8:21 pm For some reason I had it in my head that the 354 was a 360k drive and the 314 was 720k but I just read in the 314 service manual that is a 360k unit. Are both drives both sizes?
Thanks
Utr
The SF314 is a double sided drive with 2 heads and supports 720K DSDD media. It will AFAIK read SSDD media and can therefore support 360K floppies.
It is possible that there are some early SF314s that had single sided drives, but I'd expect the majority to be double sided. I'd expect you could fit a single sided drive in the SF314 enclosure and it would work fine as a single sided drive.
Re: Floppy drives
That manual is wrong. The SF314 is the double-sided drive. The enclosures are identical and either size drive can be fitted. (There are actually at least three generations of the enclosure though, small button above slot, small button below slot and long button. There may also be two long button varients, one for a Chinon drive and one for an Epson.)
Re: Floppy drives
It can be confirmed if you look at the drive heads. A lot of long button types ive seen only had 1 head.
Re: Floppy drives
Those would have been in the Chinon based SF354 drives. It was the model number which distinguished between the single-sided and double-sided drives as they were otherwise identical.exxos wrote: Wed Dec 21, 2022 4:49 am It can be confirmed if you look at the drive heads. A lot of long button types ive seen only had 1 head.
UnderTheRain
Re: Floppy drives
Thanks everyone for the replies
Hope everyone has a Merry Christmas
