DragonBall?
Other boosters or variants.
arf
DragonBall?
Post by arf »
Hi,
has anyone ever seen an ST-accelerator based on the DragonBall VZ? It’s an 68EC000 core with additions, running at up to 66 MHz and ~10 MIPS.
Or is the signalling adaption too troublesome?
Against signature spam!
rpineau
Re: DragonBall?
Post by rpineau »
It can't work as it's missing the bus arbitration pins (needed for DMA and Blitter) as well as the 6800 family interface (ACIA).
Also the MC68SZ328 (aka DragonBall VZ) is going to be EOL soon (the NXP page says "No longer recommended for new designs" (aka no longer manufactured).
Add to this that it's only available in BGA package (MC68SZ328 for the 66MHz) .. the MC68VZ328 come in a TQFP144
So even if it's close to a 68000 it unfortunately can't be use in place of a 68000.
arf
Re: DragonBall?
Post by arf »
Thanks for your explanation.
rpineau
Re: DragonBall?
Post by rpineau »
No problem. I wish we could use something like this (I even looked into this not long after the Palm Pilot was released as I knew it was a 68338 in it).
Return to “EVERYTHING ELSE”
