This is a small test program. I need somebody to run this test on an H5 with Blitter, and ideally with TOS 1.02. Other TOS versions are also useful, but, please, I would like at least one test with TOS 1.02.
The program benchmarks TOS blitting operations, in a very similar way as Gembench does. But this test counts system cycles instead of MFP interrupts. Then the result, at least in theory and if I didn't make any mistake, should be exact and identical in any computer with the same TOS version. Obviously this won't work correctly with any kind of booster.
Testing on an STE could also be interesting, but please not on MSTE because the MSTE has a slightly different Blitter timing.
And H5 is not strictly required, it could be a standard ST (or STFM or MegaST) as long as the pull-ups on the DMA control signals (BR,BG & BGACK) were upgraded. A factory ST with the original 4.7K weaker pull-ups might produce different results. And of course that Blitter is required.
Use medium resolution with Blitter enabled at the desktop, and please post the results.
Again, not on MSTE, not on a computer with an active booster or accelerator, not when using EMUTOS (standard TOS is required).
Thanks
Blitter on H5 Test
Blitter on H5 Test
http://pasti.fxatari.com
Re: Blitter on H5 Test
104 on a H5C1. MM9092V blitter.
102 on a H5C1. MM9092V blitter.
Thanks Exxos. Interesting, I wasn't expecting this result on the H5. Seems the H5, at least in this case, has the slower ST timing in comparison with the STE.exxos wrote: Tue Dec 13, 2022 2:21 pm 104 on a H5C1. MM9092V blitter.
Could you confirm exactly which pull-up value you have on the CPU BGACK signal? I though the H5 uses the same stronger pull-ups as the STE. But now, after seeing these results, I checked the H5 schematics again, and I see that the pull-up on this signal is 2K2. While on the STE schematics is 1K2 (and 4K7 on the ST).
I'm not saying that there is anything wrong with the 2K2 value. Arguably it might be better in terms of producing the same timing as the original ST. Just that I expected 1K2 as in the STE.
Anybody else? Now, after Exxos post, I would like to see the result on a standard STE and also on a standard STFM (or MegaST). Also another H5 might be useful as well.
Thanks!
Thanks!
It's 2.2K. I can soon slap a 1K in there and test again..ijor wrote: Tue Dec 13, 2022 7:44 pm Could you confirm exactly which pull-up value you have on the CPU BGACK signal? I though the H5 uses the same stronger pull-ups as the STE. But now, after seeing these results, I checked the H5 schematics again, and I see that the pull-up on this signal is 2K2. While on the STE schematics is 1K2 (and 4K7 on the ST).
I'll try on my STe by the end of the year. (edit : hopefully sooner )ijor wrote: Tue Dec 13, 2022 7:46 pm Anybody else? Now, after Exxos post, I would like to see the result on a standard STE and also on a standard STFM (or MegaST). Also another H5 might be useful as well.
Thanks!
@ijor
Should have used 2.2K I guess
But will doublecheck that as well anyway...
1K is the same as the 680R test.
EvilFranky
Dug out my STE quickly.
TOS 1.62
4MB RAM
Separate Blitter
TOS 1.62
4MB RAM
Separate Blitter
Thanks. That confirms that the weaker pull-up produces a delay. See the extra 4 cycles on tests 4-6. Again, the delay would only be significant for some blitting operations and only for code running from Rom.exxos wrote: Tue Dec 13, 2022 8:06 pm Should have used 2.2K I guessBut will doublecheck that as well anyway...
Thanks a lot! See how these results on an STE match the ones on Exxos test on the H5 using TOS 1.04 except, again, 4 extra cycles on tests 4-6. Seems all TOS versions from 1.04 to 2.06 share the same Blitter code section, or at least is similar enough to produce exactly the same timing with these tests. TOS 1.02 is rather different.
Thanks again to both.
TOS104 on a H5C1. 1K and 2.2K tests.
TOS206 on a H5C1. 1K and 2.2K tests.
I re-posted 102 here edited to align with the above tests.
TOS102 on a H5C1. 1K and 2.2K tests.
