WANTED: EmuTos eprom for Falcon 030 / 060
coonsgm
Post by coonsgm »
Anyone have the ability to burn Falcon eproms with EmuTos? I've looked into doing it myself, but haven't had much luck identifying exactly what eprom is needed and programmer settings.
I've burned ST and Amiga ROM's myself....the info is just pretty sparse (using the the all knowing google) on the Falcon.
Rustynutt
Re: WANTED: EmuTos eprom for Falcon 030 / 060
Post by Rustynutt »
I use AMTEL AT27C4096 55JU.
Arrow Electronics is in Nevada, get them in a day or two. About $5 a pop I think.
Work perfect.
If using the XGecu Pro, check the default voltage settings in the software, AIRC, it's set a bit high to the spec for that EPROM.
I'd ordered a hand full of HN27C4096HCC-85 second hand from China. Think 2 out of 6 reliability would erase.
Badwolf has a thread on here about burning ROMS for the Falcon. Good read.
Yep, here's what you need:
viewtopic.php?f=27&t=4271
Also, whilst this is for a dual TOS in an STFM, it's the same chip (and ROM image size) as the Falcon:
coonsgm
Post by coonsgm »
Thank you both! Very helpful.
