Masoboshi MVD-819 driver disk?
utri007
Post by utri007 »
I have tried to look better driver for Amiga zorro II digitizer Masoboshi MVD-819
Here is German OS1.3 driver
http://amiga.resource.cx/exp/mvd819
BBOAH says this : Two versions of the software exists, one is for use with Amiga OS1.2 and 1.3 and the other is for OS 2.0 and higher
https://bigbookofamigahardware.com/bboa ... spx?id=304
VHI Studio supports it, but it requires mvd.library v34 from install disk. Amiga Resource version is too old.
I ques this zorro card is mostly sold in Germany. It seems to be quite rare piece of hardware.
mrbombermillzy
Re: Masoboshi MVD-819 driver disk?
Post by mrbombermillzy »
Sorry, I don't have drivers for this, however, if you can provide a bigger photo than the one on BBOAH, I can maybe see if that is a Philips SAxxx IC on there like on my VLAB Motion.
If so, It's a long shot, but if the board is laid out in a similar way, you may be able to get some sort of result from the VLAB driver. (Perhaps with a bit of patching).
